hella wiring - Defender Source
Old September 9th, 2006, 02:38 PM
hella wiring
how have you guys made three hellas run off one switch. I have two with the hella wiring harness that I have chopped up a bit. thanks for any help
Old September 9th, 2006, 05:31 PM
swith all the relays with one switch!
Old September 9th, 2006, 07:31 PM
okay. its just a hella switch for now you dont think it would be too much? Also I have the hot wire for the relay jamed under the cigg lighter fuse not a good idea but I dont think its to bad of an idea? There has got to be a better way?
Old September 9th, 2006, 08:13 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I run my lights through a circuit breaker to the relay. The relay is controlled by the switch. A fuse can be used in lieu of the circuit breaker.
Old September 9th, 2006, 09:33 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Dude, use at least two relays for the three lights. The switch can run both relays. That's easy. Just makes the two outer lights on one relay and the middle one on its' own.
Old September 9th, 2006, 10:06 PM
thanks. I just need to figure it out when its in front of me I think. I was trying to think about how to tie it all into my current scheme so just thougth i would enquire. If the oil cooler lines dont burn it up i bet my wiring will.
Old September 9th, 2006, 10:35 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Nah, it's easy stuff. All of your wiring should be independent
Old September 9th, 2006, 11:49 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
True, but you can run as many lights as you want on a single relay provided its properly under the relays rating.
Here you go Phil:
For example; If you have three 100W hella lamps and run them through a single relay rated for 30 amps how do you know you won't destroy the relay? Without getting too in depth all you need to know is Power = Voltage * Current to answer this question.
In this case you have three 100W lamps, which is really 300W total power. The voltage is that of your battery, 12V. Now solve for the current. 300 Watts/12Volts = 25 amps. Since the current is lower than the rating on the relay then you can use this single relay for all three lamps. However, if it exceeds the rating of the relay then like Dave said use an additional one.
There are other issues to consider like the gauge of the wire. The thicker the wire the lower the numerical rating and resistance. What does this mean to you?
If electricity were water and then the gauge would be the tube that carries that water. Restricting the diameter of the tube (wire) will only cause the water (electricity) to back up. Hence, you need to use the proper diameter to satisfy your electrical needs and ensure the "water" doesn't back up, but flows with the least amout of Resistance.
Make sense?
DJ
Old September 10th, 2006, 01:05 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would wire the center different than the sides, too. I think that is a good idea. Ideally and ultimately, I am going to have two center lights for long distance and two wide beam floods on each side to illuminate that which is right in front and to the sides of me. But, that is down a bit on my to-do list.
Old September 10th, 2006, 07:29 AM
thanks. two euro beams and a pencil in the center.
Old September 10th, 2006, 09:08 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I think that I keep melting my relays. What would cause this, and how do I fix it?
Old September 10th, 2006, 10:42 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Most relays are 15, 20 or 30 amp. Divide your total lamp wattage by 12 volts to get the minimum relay amperage you are needing. For example, if you are running 3x100watt lamps (300watts/12 volts), you have 25 amps of wiring. I would use a 30 amp relay or split the lamps and have 2 on 1 relay and 1 on the other. If you want them all controlled together, you can daisy chain your switch to control both relays at the same time. That is the only thing I can think of to explain a bad relay. Possibly check your grounds, too.
Old September 11th, 2006, 12:02 AM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
DJ
Would "back up" cause the relays to overheat and internally fail?
I am currently running 4 Hella 3000's across the top(100w bulbs), off of two 30 amp relays. They are run off a single switch.
On my ARB, I am running 2 more 3000's with 100w bulbs, and they have a separate 30 amp relay.
All of the relays are located in the engine compartment near the bulkhead. I had both of the relays go out last week at the same time and I can't tell if it was because of moisture, heat, or "back up." I replaced them and gave them a good coating of di-electric grease and then wrapped the bottoms of the relays with electric tape, in hopes to keep the moisture out.
Old September 11th, 2006, 01:10 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I am not sure what "back up" is, but I do know there are a couple companies that make water resistant relays that are potted on the bottom and have covers. You may consider them.
wiring
hella wiring harness rover4x4 Defender Technical Discussions 19 March 6th, 2006 08:29 AM
Hella FF 1000's with wiring kit NIB Jammer 48 For Sale - Parts 0 August 15th, 2005 07:40 AM
hella city light wiring bjenk Defender Technical Discussions 10 March 8th, 2005 08:08 AM
Hella 3000 oem wiring kit 48vphantom Wanted 0 February 18th, 2005 01:13 AM
hella wiring diagram Campbell Defender Technical Discussions 1 May 1st, 2004 02:28 PM
