Hella Vision Lamps - Page 3 - Defender Source
Old May 14th, 2011, 09:14 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Originally Posted by Manimal View Post
LED is where it's at. Watch it become mainstream. It's happening right now.
Most definitely. I'm running an LED setup on my coral reef tank right now. 320w of LED beauty. Sounds like a lot, yeah, but does the work of 1kw of Halide and florescent lighting.
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 17th, 2011, 09:00 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Has anyone change their headlamps to Cibie headlamps? Thoughts?
Old May 23rd, 2011, 05:43 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Originally Posted by tjfslaughter View Post
I run these and I am very happy. The only thing better is HID or LED. The LED's look like shit.
http://www.amazon.com/15224-Style-Xt.../dp/B00067BVDC
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessories
No harness upgrades as I have been running them for years and no problems.
So I got the lamps and bulbs. I also got the painless harness in case I want brighter down the road. Should these be installed so when you're looking at them the lettering on the lamp/lense is in a normal horizontal position?
When I took out the old lamp, set in the new hella ones, and then lined up the mounting tabs on the back of the lamp and set it in the hole it was rotated off of the horizontal position by a pretty good amount. I imagine the retainer needs to be in the position it was originally fitted to allow for proper light adjustment. So am I missing something or does it matter how the lamps are orientated in there? I didn't have much time to monkey with it, so chances are I am missing something, seems like it should be pretty simple.
Pete
Old May 23rd, 2011, 08:42 PM
Broncoduecer
peter
D90
Now that I'm home and could compare the before and after pics it looks like the driver one was off to start with. Passenger looked normal. Thats what threw me off. I bet better lights plus properly aimed is going to make a big difference. Wow....
Old May 23rd, 2011, 11:16 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
The horizontal and vertical adjustment is fairly critical. Lukily Defenders have a nice fender that you can put a 2 foot level on to ensure your truck is level when you properly aim them.
In the Coast Guard we spent a lot of time leveling lights and bulbs for aids to navigation.. You would be surprised the difference it makes when you take the time to level them. The Euro Spec Defenders have switches in the dash to adjust the lights depending on the load in the back of the truck...
Old May 24th, 2011, 01:29 PM
Ummmm, you want the GROUND to be level, not the fender. Depending on your springs, the fender may not be level.
Actually, you want the ground to be in a straight line to the wall. Level is not that important. The other important thing it to have "normal" load.
Old May 24th, 2011, 10:35 PM
Broncoduecer
peter
D90
I was thinking about that. I was going to level them up tonight but have yet to put on the new bumpers, winch, and sliders. So yea going to wait for that to be put on. Good ideas guys. Thanks!
Old May 24th, 2011, 10:53 PM
tjfslaughter
thomas
Burbon
ok i will agree with that.... but my most trucks are pretty level though...
Old May 25th, 2011, 03:37 PM
Really? I think most people prefer the rear to be higher than the front.
Old May 25th, 2011, 04:04 PM
tjfslaughter
thomas
Burbon
Yes the back is slightly higher, people can adjust their lights however they want to.... What I do know is I keep the lights in about the same parallel plane as the top of the fender. I use a combination of levels and lasers to get mine set. When I drive I can see just fine.
If you really want to be anal upgrade to the ROW switch where you can adjust the lights from the inside of the truck (4 different settings). Then you can play all you want depending on load.
Old May 26th, 2011, 01:05 AM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
Do you have a webpage for ROW?
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old May 26th, 2011, 08:56 AM
tjfslaughter
thomas
Burbon
Sorry for this going way off topic. Here is the info on the light leveling. It is one switch so you need to get them level in the first place
the first attachment is a pic of the dash location for the switch.
the second is the the wiring digram. I believe it is a Hella part or a Wipac part. Here is a picture of the motor (http://landyspareparts.ecommerce.pay..._Motor_DEFHLAM)
the third is the settings
You can find them at scrap yards in the UK cheap.
ID:	39101   Click image for larger version
lamp
Hella Driving Light Add - Best? Kimos Defender Technical Discussions 43 October 26th, 2006 01:16 AM
hella vision plus headlamps Gore Ranger For Sale - Parts 3 July 1st, 2006 06:15 PM
Wiring couplings for hella lamps? wicks Defender Technical Discussions 8 October 15th, 2005 01:31 AM
mouting hella lamps khatadin Defender Technical Discussions 5 December 31st, 2004 08:56 AM
Mounting Hella 4000s with Stock Bumper/Brush Guard jbird Defender Technical Discussions 5 June 10th, 2004 06:01 PM
