hella light harness knockoffs? - Defender Source
Old January 31st, 2010, 11:32 AM
Hazard's Avatar
Hazard
David Hazard
95 D-90
So, I got a set of the hella 4000s and am looking for a wiring harness that costs below the $70 that they charge. There are several "knockoff" harnesses on ebay that seem like they should work fine. Any experience with these?
The original
http://cgi.ebay.com/ebaymotors/JEEP-...Q5fAccessories
And the knockoffs:
http://cgi.ebay.com/ebaymotors/WIRIN...ltDomainQ5f100
95 D-90 3" lift, 35" Baja claws, salisbury rear axle, 4.88 gears, lockers, winch, etc
Old January 31st, 2010, 11:53 AM
Make your own. You need red and black wire, a relay and a switch. Should cost under $25.
You will still have to run wire with any of those harnesses, since the Defender Batteries are under the drivers seat.
Old February 1st, 2010, 10:31 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I agree with Scott. I would just buy a few Hella relays off ebay (they're good to have around) and put together your own harness. This way, you have your choice of switches, and save a bundle.
fs, ht
Hella Driving Light Add - Best? Kimos Defender Technical Discussions 43 October 26th, 2006 01:16 AM
hella wiring harness rover4x4 Defender Technical Discussions 19 March 6th, 2006 08:29 AM
hella city light wiring bjenk Defender Technical Discussions 10 March 8th, 2005 08:08 AM
Hella Light Bar Plastic end Cap 48vphantom Wanted 0 December 19th, 2004 12:53 AM
Hella 3000 light covers mpodgorski For Sale - Parts 5 May 18th, 2004 02:05 PM
