Hella install warning - Defender Source
Old December 29th, 2013, 02:25 PM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
Finally installed a set of black magic 1000s and overcame the following obstacles. I thought I'd post this for posterity in case someone else encounters the same issues.
First issue was that the lamps were way too big to fit in the holders. A little "convincing" and bending got them to fit.
Then, after wiring everything up, no light. Checked the switch and it was okay. Bypassed the relay and there was light. Finally discovered that the pre-wired harness was not wired correctly to the socket that plugs onto the relay. Battery power and ground were reversed. Switched them and everything worked just fine.
Very disappointed in Hella QC.
Hella Driving Light Add - Best? Kimos Defender Technical Discussions 43 October 26th, 2006 01:16 AM
Hella Rear lamp install Defender13 Defender Technical Discussions 4 July 6th, 2006 12:12 PM
Hella rear lamp install Defender13 Defender Technical Discussions 4 June 17th, 2006 01:12 AM
Mounting Hella 4000s with Stock Bumper/Brush Guard jbird Defender Technical Discussions 5 June 10th, 2004 06:01 PM
Hella 3000 light covers mpodgorski For Sale - Parts 5 May 18th, 2004 02:05 PM
