hella 4000 wiring - Defender Source
Old May 25th, 2005, 10:28 PM
bjenk
Brian Jenkinson
1994 D90
hella 4000 wiring
I am a little confused (imagine that). I bought these lights used and am finally getting around to wiring them up. I am going to put on the gm style waterproof connections. However, I had to take them apart to find which wire is which. Here is the confusion, I see the city lights wire and the ground wire, but why do they have the ability to be connected by the t-tab? The t-tab is just on there, not pushed through (connected). I just do not understand why you would want to ground the city light wire. Any help great. I plan to take the tab off for now until I hear back
ID:	3223   Click image for larger version
Old May 26th, 2005, 03:02 PM
Brian I don't see why it is there other then to act as a bad strain relief. And like you said if it was pushed through it would short the wires and blow the fuse. I say take it off. which beam pattern did ya get?
Old May 26th, 2005, 04:18 PM
bjenk
Brian Jenkinson
1994 D90
As always thanks mike for the response. These are the hella euro beam with city lights. I went ahead and took those off (t-tab). Here is what I put on for connections, picture. I was looking at your wiring diagram last night trying to figure out what I was going to do. I want to run these lights so that I have a dash switch that turns power off, switch on by the headlight position switch (2nd position turning on the city lights, high bean turning of the euro beam), and then switch for alway on. I am just thinking of the wiring between headlight switch and dash switch with only using two relays (one for the city lights and one for the euro beam). I also plan to upgrade headlight wires while I am into this. As you can tell I have been in no hurry to get this wiring done. I guess I just like to drive it around right now with it so nice in Denver. Anyway, if you have any suggestions about my wiring feel free.
brian
Old May 26th, 2005, 04:30 PM
Plug looks good but I am not sure what you want to do with the switches. Do you want the city lights on with the headlights or the other light? Do you want to be able to switch both or just the euro beams? I can do up a revised diagram for ya tommorrow
Old May 26th, 2005, 06:06 PM
bjenk
Brian Jenkinson
1994 D90
Mike, this is what I am thinking. One dash switch with three positions.
1. off-no power to the aux lights
2. on- with power coming from the headlight switch (low beam with city lights and high beam with Euro lights)
3. on-power to the Euro beam
This is hard to explain in writing. I would like to do this an utilize only two relays. Let me know if it is possible.
Also, what guage wire did you use from your battery to your aux fuse box?
I plan to take lots of pictures just so others can see it.
Old May 26th, 2005, 06:30 PM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
Lighting.
I have my lights hooked up like you describe, you can look at my wiring I am in Conifer. Let me know.
-Josh
Old May 26th, 2005, 11:21 PM
bjenk
Brian Jenkinson
1994 D90
Josh love to look at another 90. It will have to be sometime next week.
thanks
brian
Old May 27th, 2005, 12:25 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Colorado has one of the highest cosentration of Defenders in the US. The Solihull Society is running Left-Hand / Carnage Canyon on Saturday. There will be at least 5 Defenders running the trail.
Jabber
Yousef
Princes Buttercup
Hans
and Me,
I am sure there will be more.
http://www.solihullsociety.org/
Should be great fun
--Benjamin Franklin
Old May 27th, 2005, 08:52 AM
I can draw it up! For the fuse box I ran 4 quage wire, a short length too as the fuse box is mounted next to the battery.
Here it is
Old December 22nd, 2005, 07:42 AM
Cyborg
Larry Walton
'97 D-90 ST #2066 UK 4X4
I have a general question about auxillary lighting. I am getting a couple of Hella lights for Christmas. I will be mounting them to the front of my roof rack and am wondering what is considered to be the best way to run the wiring to the interior?? I am sure there is a method that is considered the standard way but to me it is not obvious. any thoughts would be appreciated..
Larry
Visit the Land Rover Beer Bar,"The Best Beer Bar X Far!"
Old December 22nd, 2005, 07:52 AM
Most that I see run the wires up on the cage around the window. SOme drill a small hole in the cage and un it up inside the cage.
Old November 23rd, 2011, 05:43 PM
D110
Jamie
1955 107
Digging up this old thread as I am finally getting around to installing my Hella 4000 Eurobeams and was wondering how most people have their's installed - I bought the wiring harness and was disappointed that the switch wasn't a three way switch. I had been thinking of wiring the lights independent of the light switch, and using a three way switch so I can have just the city lights on. Any thoughts on having the lights independent of the headlights - pros/cons? Is there any point in using the wiring harness if I am not setting them up to work in conjunction with the headlights? Thanks for any input.
wiring
2 Hella 4000 (Euro Beam) plus Hella wiring harness Gore Ranger For Sale - Parts 9 January 2nd, 2010 08:26 PM
Hella FF 1000's with wiring kit NIB Jammer 48 For Sale - Parts 0 August 15th, 2005 07:40 AM
hella city light wiring bjenk Defender Technical Discussions 10 March 8th, 2005 08:08 AM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
Hella 4000 lights! TwisteD90 For Sale - Parts 17 October 7th, 2003 04:32 PM
