Hella 4000 Light switch - Defender Source
Old January 3rd, 2012, 08:42 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Hi,
I want to change my switch for my Hella 4000's. I'm using the hella wiring harness and was hoping to use a rocker switch like this I saw on amazon. Does it matter which switch I use?
Old January 3rd, 2012, 08:58 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I am sure others will chime in, but make sure you get a two position on-off, and not a three position or momemtary on switch.
Semper Fi!
Old January 3rd, 2012, 09:34 AM
Campbell's Avatar
Campbell
Rich Campbell
I see most of the the switches I see have three pins on the back while I only need 2.
Old January 3rd, 2012, 09:46 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
You can use the Carling switch without any problems (this is how i have my Hella's switched)...just follow the wiring diagram and as Jonathan said, make sure you get a simple on-off switch.
Old January 3rd, 2012, 09:47 AM
Campbell's Avatar
Campbell
Rich Campbell
Thanks. I appreciate it.
Rich
------ Follow up post added January 3rd, 2012 03:02 PM ------
think this would work ok?
http://www.amazon.com/gp/product/B00...pf_rd_i=507846
Old January 3rd, 2012, 05:07 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
mud uk sells those
Old January 3rd, 2012, 05:20 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
That should work fine.
Here are some more options with different colored illumination choices and labelled:
Blue
http://www.otrattw.com/proddetail.php?prod=V1D1J66B-AYCN5-17U
Green
http://www.otrattw.com/proddetail.php?prod=V1D1J66B-ALCN5-17U
Amber
http://www.otrattw.com/proddetail.php?prod=V1D1J66B-AFCN5-17U
There are 2 lights on these so you can wire them up so that 1 lights up with the dash lamps and the other only when it is turned on. Or you can just leave them unwired, up to you.
HTH
Ian
Old January 3rd, 2012, 05:52 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
I have the green Carling...they work great...you just need a second power to run the light on the switch.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old January 3rd, 2012, 07:53 PM
Campbell's Avatar
Campbell
Rich Campbell
Sweet! Thanks for l the options.
Old January 4th, 2012, 09:31 AM
I would use a factory land rover switch. They are like $30 but look exactly like the ones for the dimmer.
Ron
ht, switch
Can I use a Dome light switch for hella lights tebby Defender Technical Discussions 4 September 5th, 2009 11:12 AM
4 Hella 4000 Light Covers, Fan Switch, Camo seat covers ini88 For Sale - Parts 1 February 11th, 2008 02:37 AM
Hella Driving Light Add - Best? Kimos Defender Technical Discussions 43 October 26th, 2006 01:16 AM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
