heavy smoke - Defender Source
Old February 10th, 2006, 03:14 PM
steved90
steven melnyk
heavy smoke
afternoon all,
went to the garage this morning and started the d its been a few weeks since it has been started. anyway when i fired it up it was a fairly heavy blueish exhust coming out of the tail pipe. last summer the check engine light when on and i had a friend check the code and he told me it was the sensor and that it might need to be replaced the one near the bulkhead. could that be what needs to be replaced? i have to get new tags soon and they will do a sniff test and i am sure that it will not pass. what could this be??
thanks!
Old February 10th, 2006, 03:36 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Blue smoke is oil, how many miles you got? How long was it sitting?
Might just be the PCV valve possibly, or oil might have slowly dripped into the cylinders through bad valve seals.
I'd suggest starting with a good 20 minute drive, then see what it does the next morning. If it does it again, then do a compression test.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 11th, 2006, 09:13 AM
gali
Gali k
TDI or V8?
Old February 11th, 2006, 12:58 PM
steved90
steven melnyk
v8 and it has been sitting for months whiles things get fixed as i have time and funds.
i should probably run it more often just to keep things moving.
Old February 11th, 2006, 05:32 PM
Drive it like a nut (shifting at 4000rpm) for a few days, be sure you're flooring it, that should clean everything out.
Old February 14th, 2006, 03:37 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Change the oil, use engine flush. maybe things gummed up while it was standing, like piston rings.
Mike Hammond
Heavy Duty winch bumper for 90/110 k4rovers For Sale - Parts 2 December 28th, 2005 01:06 AM
Heavy Duty Front Bumper david_jackson Wanted 2 January 5th, 2005 07:07 PM
Bearmach Springs Heavy Duty... h2eater For Sale - Parts 0 July 9th, 2004 12:40 PM
GBR heavy duty drive flanges jorge Defender Technical Discussions 2 February 29th, 2004 11:51 PM
