Heavy duty 110 drive flanges - Defender Source
Old July 26th, 2009, 10:14 PM
At the risk of sounding really lazy and/or stupid, will these drive flanges work on both the front and rear of an '84 110?
http://www.roversnorth.com/store/p-1...ender-110.aspx
I"m tired of tearing the plastic ones and these look like they would be just the ticket. It's dark out and I don't feel like going out there and pulling 2 caps and counting splines, but I believe they are 10 spline front and rear, but want to confirm.
thanks,
charles
Old July 26th, 2009, 10:19 PM
plastic ones? all the splines are 24
thanks,
charles
Old July 26th, 2009, 10:22 PM
Plastic caps. I tear them pretty much any time I go wheeling
So I want to replace the flanges with those ones with the screw on metal caps.
But I thought the 110s were 10 spline?
RN says those are for early 110s but there is no mention of spline count. I just want to make sure they will work on Janey before buying them.
charles
Old July 26th, 2009, 10:27 PM
They will work front and rear. Both are 24 spline at the drive flange and the thick style. The inner axle at the diff in front is 10 spline which goes to 23 spline inside the cv and the outer at the drive flange is 24 spline. Rear is 24 spline on both ends.
Old July 26th, 2009, 10:30 PM
Cool! Thanks for the input guys, I figured a couple of you would be online
Any idea why they differentiate between the early 110 flanges and other defender/discos?
http://www.roversnorth.com/store/p-1...o-def-rrc.aspx
vs
Not complaining as these are cheaper
thanks,
charles
Old July 26th, 2009, 10:33 PM
The later ones are thinner.
Old July 27th, 2009, 01:11 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
If you are just looking for a fix, you can weld a solid washer to the outside of the drive flange you already have. It won't be as pretty, but it can be close, depending on how well you weld. I did this to mine when I couldn't get them to stop leaking. It's a lot cheaper than $240 and worked very well. I can't figure out why you need to be able to open it.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 27th, 2009, 01:12 AM
How does that work there is no flat end as the inner axle protrudes and has a snap ring? BTW $69 a pair x 2 = $140.
Old July 27th, 2009, 01:43 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I thought it was $69 each. My axles didn't have the snap ring. They were custom. The flanges were stock modified though. Thought it would work for anybody.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 27th, 2009, 08:24 AM
to be more precise, the difference between the two is that on the early axles, the stubs are longer and the hubs are narrower. This means the distance between the hub mating face to snap ring land is greater. if you put the early flange on a late axle it will work but the outer end will not be fully engaged in the splines. later hubs and stub axles are of a more similar length and thus are almost flush with each other, allowing the use of a much narrower flange and of course alloy rims etc with a tighter fit to the hub.
vs
thanks,
charles
Old July 27th, 2009, 12:35 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have the old style on my truck up front with the 1 ton CV's They stick out a lot further..
Legend in My Own Mind.
Old July 27th, 2009, 12:54 PM
Originally Posted by JSBriggs
Will a metal series dust cap work?
-Jeff
Probably. Didn't know they existed! Oh well, already on order and with any luck will also reduce some of the driveline slop.
Old July 27th, 2009, 02:20 PM
I will try when I get home, but the metal ones dent badly. BTW Cgalpin, save your old flanges as spares for others the rear ones wear badly and often need to be replaced.
Old July 31st, 2009, 03:50 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Wear ...
And how much is allot of wear ?
Pat
Kirk Lazarus, Tropic Thunder
Old August 5th, 2009, 10:08 PM
To wrap up this thread, here is what they look like installed
Old August 5th, 2009, 10:16 PM
b-ling b-ling!
Old August 5th, 2009, 10:19 PM
That's how I roll
Old August 5th, 2009, 11:35 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Put similar ones on Karen's truck and got roasted for the bling! I went to the shop and retrieved a can of Rattle can satin black and promptly painted them (black Wolf wheels) in place... She's happy now... I'd leave mine Bling, it would be the shinyist think on my 110...
Keith
Big, Red and ... aaa Red..
110 Middle Row FLOORMAT - Heavy Duty? STC50173 pcscharfe Misc. Chit-Chat 14 May 29th, 2009 05:02 PM
Heavy Duty OME & the works Rover- Girl Wanted 1 January 30th, 2006 09:21 AM
Rovertracks HD front axles CV's & GBR drive flanges ToaDisco For Sale - Parts 8 July 4th, 2005 01:50 PM
GBR heavy duty drive flanges jorge Defender Technical Discussions 2 February 29th, 2004 11:51 PM
