heather electrical help - Defender Source
Old October 22nd, 2008, 09:20 PM
Noah's Avatar
Noah
Noah
95 D90 TDI
hello all-
I'm trying to get my heater working before it gets really cold...
When it died & I stopped using it last spring it sounded as if the blower motor was crapping out (lots of squealing, very little air pressure, no heat). I'm trying to get it to work *at all* and no luck. There is no voltage at the low speed resistor/blower motor and no voltage on the switch in the dash either. All my fuses appear to be good. Where should I look next? According to the wiring diagram I have there isn't much else involved....
The "slow death" nature of what happened made me think it was the blower but I have a new blower and it ain't that.
Old October 22nd, 2008, 10:35 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Who's Heather?
legend in my own mind
Old October 22nd, 2008, 10:56 PM
Originally Posted by pendy
Who's Heather?
Your mom.
Couldn't resist.
Those dash switches do go bad. You can apply 12v to directly to the fan and it blows? Is your new blower installed and squeaking etc? I'm a little lost on the chain of events.
Old October 22nd, 2008, 11:18 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Originally Posted by JimC
Your mom.
Couldn't resist.
As is he-
Don't skip from A to B so quickly Noah.
Jim do you have an older sister?
Old October 23rd, 2008, 07:27 AM
Noah's Avatar
Noah
Noah
95 D90 TDI
I did jump pretty quickly to assuming it was a bad blower but if you had heard it dying you would have too. It would squeal, randomly jump around in how much air it was blowing, not work at all most of the time. And this all got gradually worse. The new blower is just sitting on the sidelines at this point. Nothing is installed or back together; the whole deal is ripped apart.
Applying 12v directly to the old fan (w/o the low speed resistor hooked up) produces nothing. But then in addition and I can't get 12v at the dash switch either (pulling the plug off the lever tab and testing on that). Where does the hot lead come from?
And HI JIM!!!!!
sorry I missed you out west this year. Somehow I've been tricked into farming and working seven day weeks. I haven't even driven the rover once all summer.
Old October 24th, 2008, 08:04 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I have a D90 style heater/blower in my 110. When I wired it up, I recall that the hot lead went to the blower. The switch for the two speeds basically connects the circuit to ground. So if you have a bad connection in the blower, you won't see 12V at the switch. I would disconnect the connector at the blower, and check for power there. If it's the same color coding as mine, 12V should be on the purple/green wire.
Old October 24th, 2008, 08:20 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
As is he-
ROFLMAO If so whats her name...
Old October 25th, 2008, 08:20 AM
Noah's Avatar
Noah
Noah
95 D90 TDI
Thanks.
Old October 27th, 2008, 06:24 PM
Noah's Avatar
Noah
Noah
95 D90 TDI
It was both a wonky fuse that lit up the tester though was not actually making a good connection and a bad blower motor. I have heat again.
electrical
Tdi electrical diagram artm Defender Technical Discussions 2 January 13th, 2006 08:52 PM
Help With Electrical Gremilins mdmccallum Defender Technical Discussions 8 January 7th, 2006 01:24 AM
Electrical problem whistler110 Defender Technical Discussions 10 December 12th, 2004 12:25 PM
Electrical for beginners paulb Defender Technical Discussions 5 October 18th, 2004 01:58 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
