Heater-speed Question? - Defender Source
Old October 4th, 2017, 07:58 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I know the mid nineties heater controls had 3 notches and 2 speeds, low and high. My question is wether the speed are cumulative?
My heater only works on the 3rd notch (high) and it's very weak, I'm wondering if my 2nd notch (low) actually worked proper, would it add push to my high setting?
Old October 4th, 2017, 08:12 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Use to think that the first notch opened a flap and the other 2 were Hi and Low fan speeds, but someone could perhaps chime in to confirm or correct.
I do know the blower is one speed with a resistor that reduces the current to about half speed.
Low speed is power through the resistor and high is power around the resistor directly to the brushes.
Speeds are half and full which explaining the weak air-flow.
Sometimes the switching arm can get bent and prevent contact as well.
RDavisinVA
Old October 4th, 2017, 09:44 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Great thanks
I'll look at it before I order a new one.
Old October 4th, 2017, 09:48 PM
You need to troubleshoot to see if the problem is the switch or the blower resistor or the fan. First step is to understand the wiring.
Old October 5th, 2017, 07:39 AM
just pull the three-conductor plug in the engine bay and apply 12V and ground to the proper terminals, and you've got your answer
heater
93 RRC heater core question Mtanzania Defender Technical Discussions 2 January 5th, 2014 09:25 PM
Heater vent control question jayz Defender Technical Discussions 4 September 10th, 2011 08:09 PM
LHD Heater Mounting Question 16kpsi Defender Technical Discussions 2 April 26th, 2010 02:39 PM
A/C and heater question Overlander Defender Technical Discussions 9 January 19th, 2008 07:50 AM
Another heater output question GaryBaxter Defender Technical Discussions 19 January 15th, 2008 06:31 PM
