Heater Slide stuck!!! - Defender Source
Old May 24th, 2007, 10:21 AM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
So the heater slide is stuck in the heat position. Isn't fun cooking my feet in the summer.
What's the best way to get it unstuck? Brute force doesn't seem to be an option.
Thanks!
Old May 24th, 2007, 11:41 AM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
Pull off the panel and look at it. It's pretty easy to figure out. The catch gets worn then sticks. A few seconds with a file and a shot of oil and it'll work like new. It's a fairly common problem.
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
heater, slide
Thermostat Stuck Open? johare Defender Technical Discussions 12 March 16th, 2006 08:58 AM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
» Defender Registry
Rangie
pl626
B240 SNW
Sandt
Add your Defender
