Heater problems - Defender Source
Old January 3rd, 2013, 11:50 PM
Trooper90
John Capps
1986 ninety
Heater problems
I have an ex-mod 90 that no longer blows warm air, or air at all, I am getting about 13 volts at the connector before the relay but the blower is not working. The fan spins freely, and some air will move when at highway speed. Any help appreciated, not real good with electrics, especially British! Thanks
Old January 4th, 2013, 12:13 AM
DGH
David Howe
Your description is a bit cryptic but I'll take a stab at this. Correct me if I am wrong - by "no longer blows...air at all" you mean that your fan is not working when it should.
Test #1 - Can you apply power and a common to the fan connections to see if it will spin?
Question #1 - When you say "at the connector before the relay" do you know if that's the switch or the coil circuit?
2011 LR4 Metropolis (white)
2003 DII Santorini Black (I think)
1981 FJ 40 Beige
Defender - in the market
Old January 4th, 2013, 08:07 AM
Trooper90
John Capps
1986 ninety
Yes that is what I mean, it does not blow at any fan speed.i would like to test the fan but do not know how,without hurting it, and the connector is at what I believe is the coil (under the left wing)
Old January 4th, 2013, 08:46 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
there are 2 wires near the fan with a quick disconnect ... disconnect and get a pos and neg wire to the motor if motor spins then the problem is upstream... my bet is the motor. if the air intake gets full of water it backs up into the motor and shorts it out good luck i have replaced 3 motors in my defenders.
Old January 4th, 2013, 09:40 AM
The fans are switched on the ground side, so make sure both ground and power are good.
Old January 6th, 2013, 06:47 PM
Trooper90
John Capps
1986 ninety
Okay, I'm going to try to work on it tomorrow and I'll post what I find, thanks for the help,oh and 1 more dumb question where should I get the power to test the battery?
heater, problems
A/C + heater problems melittle Defender Technical Discussions 6 November 7th, 2012 03:24 PM
The "Increase your heater output" thread Overlander Defender Technical Discussions 25 February 28th, 2012 06:42 PM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
