Heater Pipe Filler Tower - Defender Source
Old November 14th, 2006, 10:07 AM
Grover's Avatar
Grover
Question Heater Pipe Filler Tower
Anybody out there know the purpose of the filler tower? (it is located along the heater pipe on top of the passanger side valve cover) I am about to replace my heater/coolant hoses. The workshop manual states to re-fill via the radiator fill-plug, however the owners manual states to re-fill using the "Filler-Tower". Which one do I use to re-fill the coolant after changing hoses?
Cheers...
Old November 14th, 2006, 10:28 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
I filled both, just to squeeze as much air out of the system as I could.. Let the overflow tank and drain deal with any extra fluid..
~Steve
Old November 14th, 2006, 12:31 PM
Grover's Avatar
Grover
Question
Steve,
Thanks for the reply. Just to clarify, you re-fill via the "filler tower" and the fill plug on the radiator therefor allowing any remaining coolant fill into the overflow tank? As I recall, the overflow tank is slightly higher than the filler tower.
Cheers...
After more research, I found this reponse from Mike Smith @ ERC...it's exactly what I was looking for...
http://www.defendersource.com/forum/...61&postcount=2
Cheers...
heater
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
4.0 heater pipe Mike Hippert Defender Technical Discussions 8 May 29th, 2005 07:37 PM
Adding a Side Tank - Alternate Filler Method JimC Misc. Chit-Chat 6 October 25th, 2004 12:29 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
