Heater inlet, to cover or not - Defender Source
Old February 26th, 2015, 11:37 AM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
What is the consensus of having the heater inlet vent covered or not...does it restrict airflow in thru the cabin? What is the real purpose of the covers?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old February 26th, 2015, 11:43 AM
The one in the picture is designed to restrict airflow to make the passengers colder. Although some mistakenly believe it is supposed to produce a "ram" effect, forcing more air through the fan. But since the fan CFM throughput decreases with the increased static pressure caused by sucking through a smaller straw, any benefit is most likely negated.
Oh, and hey, they look cool.
Old February 26th, 2015, 11:58 AM
They are all restrictive. The stock vent cover itself is restrictive and I have not seen any cover that has as much area as the stock cover.
Old February 26th, 2015, 12:00 PM
By stock cover, you mean the flat plastic grille that is on there from the factory?
Old February 26th, 2015, 12:31 PM
Yes.
Old February 28th, 2015, 12:30 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Might be restrictive (all of 'em). I have a mud uk snow cowl and it doesn't make much difference with the original plastic finisher. Major difference is in the longevity of the blower. Less rain/snow means longer life!
------ Follow up post added February 28th, 2015 12:32 AM ------
I know there's a dump valve in the plastic duct... But mist of rain will fly right over it!
cover, heater
MoD style heater inlet Roverlab Wanted 9 April 8th, 2011 04:52 PM
5AM MAF, 2 newer o2's and rubber inlet $85 shipped eliaschristeas For Sale - Parts 0 November 11th, 2010 01:04 AM
Fuel inlet size on side of tub MUDSUX Defender Technical Discussions 4 July 18th, 2010 09:21 PM
300tdi inlet manifold cabell Wanted 1 June 26th, 2008 06:46 AM
muffler inlet size kolvedic Defender Technical Discussions 1 February 10th, 2006 06:29 AM
