Heater hookup - Defender Source
Old April 3rd, 2005, 11:01 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Heater hookup
How do I hook up this heater cable to the heater box. ? Can someone take a pic of theirs so I can see what I am missing?
ID:	2877   Click image for larger version
Legend in My Own Mind.
Old April 3rd, 2005, 11:49 AM
This work
ID:	2879   Click image for larger version
Old April 3rd, 2005, 11:54 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mike, doesn't it look like mine has a different hookup then your center pic? Mine just has a bar with a pin
Old April 3rd, 2005, 12:06 PM
Here's a close up, maybe you just wrap the wire around the bar?
Old April 3rd, 2005, 12:08 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
mine is totally different. the arm on the hearer just has a pin on it. Ou can see it in the first pic
Old April 3rd, 2005, 12:10 PM
Well, you could use some duct tape, at least it will match the paint . You must have a newer style or something. Heat's over rated anyway.
Old April 3rd, 2005, 01:29 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yeah, I have the newer heater. Maybe a 97 has this style hookup. I looked in the parts book and there is no pics of this at all.
Old April 4th, 2005, 11:54 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Anyone?? What about you euro guys?
Old April 4th, 2005, 12:46 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
The 97 hookup is the same as Mike's. Maybe try posting to the LR Enthusiast forum. Lot's of Euro presence there.
Old April 5th, 2005, 06:31 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Mime will be far too early - 1985 but I'll photo if you think it'll help.
In fact my heater is even earlier than Mike H's. The heater is the same style as the 300 tdi.
Mike Hammond
Old April 5th, 2005, 07:40 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Does anyone have an old heater box that you can salvage the arm off for me? I was told by George from RDS that the heater I have has an arm on it that LR made a mistake with then later corrected it so there are no parts for it. HE said to change the arm to the standard style. Can anyone help?
RAndy
Old April 6th, 2005, 03:09 AM
mikeslandrover
Mike Hammond
If you get really stuck I know of a field near me with several LRs being broken. But I'm in GB and you're in NJ..... there'd be some postage and probably a token amount for the bracket & lock screw
Mike Hammond
Old April 6th, 2005, 08:56 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mike, I might take you up on that. I have one more place to look today. IF not, That would be great and I will send payment for whatever it costs... These little pieces are a pain in the ass.
Old April 6th, 2005, 10:10 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
why dont you crimp a ring on the end of your wire and thread the post on the heater arm. Place the ring on the post and thread a nut onto the newly thread post to secure it. That should work.
Old April 6th, 2005, 01:31 PM
mikeslandrover
Mike Hammond
Do it right......
or don't do it at all.
Mike Hammond
Old April 6th, 2005, 02:11 PM
sheki's Avatar
sheki
David Shechter
Since it is a defective part, what's the right way? What's your solution? Open the wallet and dole out cash for a new part without seeing if you can make this one work? What is there to loose but maybe 20min worth of labor
Old April 6th, 2005, 03:28 PM
I have too agree, I have "modified" things when I didn't have the parts I needed on hand to do the job. And when it's something as small as the heater controls I would not be to worried if I had to rig it with duct tape, bailing wire and bubble gum, not that I would . But what Dave suggested sounds like a good idea to me.
Old April 6th, 2005, 11:32 PM
sheki's Avatar
sheki
David Shechter
Thanks for backing me up Mike. I mean come on... it's a Defender not a 2005 Range Rover.
Old April 7th, 2005, 03:19 AM
mikeslandrover
Mike Hammond
www.d-90.com/forum/showthread.php?p=36961
Does this look like the work of a guy who bodges
Well anyway, Randy just drop me an email if you want me to nip along and salvage the part/parts. Will you want both arms - on/off and "temperature control"?
I can't see that it'll cost that much at all.
Mike Hammond
Old April 7th, 2005, 07:08 AM
OK to make things even Randy buy the part from Mike, then wrap it in duct tape , and this better not hold you up going to Rausch!
heater
New "American Style" Heater hookup tomaco1 Defender Technical Discussions 4 November 18th, 2008 05:32 PM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
