Heater fan works with ignition off - Defender Source
Old December 29th, 2009, 09:27 PM
Ideas? Could have a battery drain problem too.
Old December 30th, 2009, 08:45 AM
are there other things that are working that shouldn't be? Could be the ignition switch or fusebox is wired incorrectly. Rover basic wire colors haven't changed much over the years, green=ignition switched and should cover things like heaters, indicators, gauges (senders are switches I guess) wipers, etc. White=ignition unswitched, and should cover coil 12v, starting circuit, and power to all the green items. purple and brown are always live 12v switched and unswitched respectively. hope that helps.
fan, heater
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Dead Heater Fan chris snell Defender Technical Discussions 4 January 25th, 2006 11:07 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
