Heater fan upgrade in the NAS D-90???? - Defender Source
Old July 7th, 2012, 11:13 PM
Doc Martin
Dr. Martin Ferrillo
1995 D90 conv
Has anybody upgraded there heater fan? I use my 1995 d90 as a winter car in upstate NY and although my engine temp is up to normal operating temp in 5 minutes, my cabin temp stays abysmally cold due to lack of heat output. My defender even has an arctic heater too under the passenger seat but that works poorly in conjunction. I recently found a heater fan upgrade for my classic MGB and I thought that there might be a similar upgrade available for a defender???
Old July 7th, 2012, 11:40 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Seems like you already have the upgrade (artic heater
Sent from my iPhone using Forum Runner
------ Follow up post added July 7th, 2012 11:44 PM ------
Originally Posted by CDNRover
Seems like you already have the upgrade (artic heater). I thought V8 gave enough heat to warm up the interior? A partly block heater matrix? Blocked duct? Do you feel air coming out of the vents? If so it's only cool air? If your system is tip top and ain't enough to suit you then, try webasto cab heater. It'll fry your buns in there!
Cheers
Old July 7th, 2012, 11:59 PM
drop curtain
Old July 8th, 2012, 08:23 AM
Doc Martin
Dr. Martin Ferrillo
1995 D90 conv
The heater blower motor needs to move more air. The arctic heater is equally weak at moving air and warming up the cabin.
Old July 8th, 2012, 12:05 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
The PO in Wyoming installed in my NAS ST what I understand is a GM truck blower motor that is a straight drop in. It blows hard and can maintain the interior at 70 during the winter. Badger softtop probably helps here as well. Let me know if you need the part number of the blower -- or search the threads. The part number is listed in here some where.
Old July 8th, 2012, 12:52 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I've always wondered this as, even with the modifications to the bulkhead, the output of that fan/motor is truely abysmal.
I'd love that part number.
Old July 8th, 2012, 09:23 PM
Put me on that list too! I don't even think mine works so probably needs to be replaced anyhow.
Old July 9th, 2012, 12:09 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
Mine died this week.. I could use that info as well... Thanks.
Old July 9th, 2012, 05:00 AM
I'm puzzled to since the heater matrix is bigger than the unit in Ford's expedition and alike.
RN's Mansfield unit does wonders for series trucks
Old July 9th, 2012, 08:14 AM
I could use that part number, my fan doesn't work when temps are below 30* or so.
Old July 9th, 2012, 08:28 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Would love it as well, mine is halfway out anyway.
Old July 9th, 2012, 09:47 AM
down_shift's Avatar
down_shift
Russell
http://www.defendersource.com/forum/...74&postcount=3
Until I can get under my hood, here is a starting point.
Old July 9th, 2012, 09:49 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
From a thread over on Guns and Rovers, the part number is PM136 and can be found here:
http://www.autozone.com/autozone/par...ier=15918_0_0_
thread link:
http://siteground237.com/~gunsandr/s...d-Heater/page2
looks like a pretty simple swap with a little cutting needed but the blower is cheap!
Old July 9th, 2012, 09:52 AM
down_shift's Avatar
down_shift
Russell
Bingo: http://www.defendersource.com/forum/...1&postcount=12
Napa G.M. blower motor # M-4722 or GM 14-8154-4
Old July 9th, 2012, 09:59 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Another decent thread on the actual install...this guy actually put the LR cage on the GM blower motor to avoid some of the other modifications
http://www.tukojack.com/livelearnrur4.htm
Old July 9th, 2012, 12:46 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
I think you already have the easy solution to your fan upgrade - the MG unit.!
the MG blower from memory has a bigger- longer fan, I think this will fit in the heater assembly on your 90.
there are also lots of threads on here about sorting out the air leaks in the heater assy which allow the blown air to bypass the heater matrix.
There is also a thicker heater matrix available from bearmach p# ba2370 & BA2380.
the links to the GM Mod on tuko jacks website are for series 3 heater assembly's not 90/110.
regards
Gren
Old July 9th, 2012, 12:56 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
regards
Gren
Thanks for the correction on the Tuko link and you are correct...I found the link in another thread but didn't verify the vehicle before posting here.
Old July 9th, 2012, 03:55 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
The biggest upgrade I did to my heater was to put on SW doors; I even stopped using the drop curtain after that so if anyone needs a drop curtain..............SW doors =- huge improvement! It gets really cold (routinely below zero) here as well..............
Todd
'95 D90 #2206
'66 109" P/U
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Yeah I used that write up as a basis for what I'm trying to do to mine. He had to fab up a spacer between the motor and the blower housing. I'm working on a S3 truck. Trying to find a fan that has enough of an offset so that there is no need for a spacer between the motor and housing.
Old July 9th, 2012, 09:32 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
My diesel will bake you out. But have heard the gas motors do not do as well with the heat. Have you tried a scoop intake on the fender to draw in more air.
Land Rover 110
90, d-90, fan, heater, nas
'93 NAS D110 AC Condenser Fan Jon_Winningham Wanted 19 January 17th, 2015 11:49 AM
1997 Defender 90 NAS Station Wagon, Coniston Green, Galvanized Frame 74k miles Boone90 For Sale - Vehicles 24 September 15th, 2012 10:59 PM
FS used NAS 90 frame ECR The Vendors Loft 2 March 28th, 2011 08:42 AM
Safety Devices NAS 90 Roof Racks ECR The Vendors Loft 47 September 14th, 2010 09:28 PM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
