Heater fan upgrade in the NAS D-90???? - Page 7 - Defender Source
Old February 18th, 2016, 01:51 PM
just started on this wonderful journey...and I gather from John/Jason et al that the bulkhead opening needs an additional 2" to the pass side- correct?
I have a bare bulkhead right now so I want to get this out of the way while it's easy to cut and access!
I opened up 1.5" to 6", see here: Land Rover Defender Heater Upgrade - Page 1 which, IIRC, matched the full width of the stock heater.
Old February 18th, 2016, 02:15 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
To be clear is there any notching that can be done on a RHD 90/110/127?
Old February 18th, 2016, 02:20 PM
adjust the vents is a good start ... they get out of adjustment and don't seal
Old February 18th, 2016, 02:21 PM
I don't think so. I have not looked at it in person myself, but IIRC, from photos, the heater plenum inside the truck ends at the edge of the hole through the bulkhead.
Old February 18th, 2016, 02:25 PM
IMO..... The vents in a non-AC truck are the main restriction and these can do with a fair bit of opening up. From my page info...
Bulkhead hole: 4.5 x 3.25" = 14.6 sq inches.
Dash vents: 2@ 1-3/4" x 2-1/4" = 7.8 sq inches.
Stock fan inlet = 14 sq inches.
From those simple measurements, the dash vents restrict air flow much more than the bulkhead hole.
Old February 18th, 2016, 02:39 PM
JohnsD90's Avatar
JohnsD90
What vents are we talking about?
Old February 18th, 2016, 02:49 PM
This is correct, no mods needed for RHD.
Old February 18th, 2016, 02:56 PM
There should only be two vents in the dash of a normal Defender unless you have AC.
Old February 18th, 2016, 03:06 PM
Pull the heater box away from the bulkhead. You will be able to see if the openings are the same.
-Jeff
The answer is no...
http://www.defendersource.com/forum/...tml#post614350
Old February 18th, 2016, 03:07 PM
JohnsD90's Avatar
JohnsD90
Gotcha, thanks, I was confused as NYC Jason said they were "adjustable".
-Jeff
Will do, the unit is coming out tomorrow to get a new heater core anyway, will do the fan while I am at it.
Old February 18th, 2016, 05:56 PM
He's talking about the blend doors in the heater box.
Old February 20th, 2016, 08:55 PM
JohnsD90's Avatar
JohnsD90
I bought PM137, which i think is the same exact size as PM136, the difference I believe is that PM137 is not internally grounded and has 2 connectors on the outside which when I put power and ground to them, it made it spin, and when I flipped the power and ground, it spun the other way. You can also buy the pigtail connector from autozone so you can have a "nice" connection.
Old March 3rd, 2016, 11:45 AM
JohnsD90's Avatar
JohnsD90
I installed the PM137 Fan, new heatercore with new insulation around the core, It is definetley an improvement, I do not know how much better it was though.
I also removed the Driver side lower plastic vent and that greatly improved the airflow. I didn't pull the passenger one as I like the restriction there to send more air to the driver side.
The Wolf Rad Haz TUM Radiation kit greatly helped retain the heat within the cabin.
Old April 19th, 2017, 08:56 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
When swapping out the fan with a PM136 or PM137 and installng the new connector as shown in this thread, post 59, what happens with the little silver box that is attached to the stock fan. It appears that it might not get used?
Any help is greatly appreciated.
Old April 21st, 2017, 08:01 AM
buckyballz
Dave
'87 90 military soft top
That's the interference suppression filter, originally fitted to an FFR/ military radio truck. As long as the motor is the same voltage as your truck - fit it as normal, then mount the box using screws to a good earth and that's it. Enjoy
90, d-90, fan, heater, nas
'93 NAS D110 AC Condenser Fan Jon_Winningham Wanted 19 January 17th, 2015 11:49 AM
1997 Defender 90 NAS Station Wagon, Coniston Green, Galvanized Frame 74k miles Boone90 For Sale - Vehicles 24 September 15th, 2012 10:59 PM
FS used NAS 90 frame ECR The Vendors Loft 2 March 28th, 2011 08:42 AM
Safety Devices NAS 90 Roof Racks ECR The Vendors Loft 47 September 14th, 2010 09:28 PM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
