Heater fan upgrade in the NAS D-90???? - Page 6 - Defender Source
Old March 27th, 2013, 10:21 PM
Originally Posted by Overlander View Post
If you think you can get a quick response from him, go for it! I don't think anybody on this forum is following any other thread right now! lol
Shot him an email.
Old March 29th, 2013, 12:46 AM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
"Dude in Canada" here.
Just measured up the cage on the motor I got from Jason and it shows 5 3/8 inches across and 2 1/2 inches high. Hope that helps.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old March 29th, 2013, 09:53 AM
Brett
Thank you Brett!
Mark Kellgren
KM4BOR
Old March 29th, 2013, 03:32 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I'm about to tackle the PM136 this weekend. The motor is sitting here on my desk. Wondering if I should wait now...
Old March 30th, 2013, 10:16 AM
David, can you post up the cage measurements on the PM136? I'll try to get PM138 measurements this weekend. The final question will come down to how much clearance is there for cages in the heater cage housing? is there room for slightly wider? slightly longer?
Mark Kellgren
KM4BOR
Old March 30th, 2013, 12:18 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Will post up and can tell you as soon as i pull the housing to increase the firewall hole.
Old April 27th, 2013, 10:56 AM
Update: At this point I've suspended the heater fan upgrade on my truck due to a new development. Throughout the winter, I noticed that my heater fan output when my Webasto is running was always double the flow of the heater running in normal configuration, but I never got around to investigating it. I suspected that somehow, my Webasto wiring install had an error in it and as a result, I suspected that my normal fan circuit was running through a Webasto harness resistor somehow. Well I finally investigated it last week. What I found was that I had wired the Webasto correctly. Let me explain further:
The webasto harness uses a relay to control the heater fan + lead. In normal configuration without a Webasto, the positive lead is fed through the a switched lead running from the fuse panel directly on a 16AWG wire. with the Webasto, the Webasto battery + lead (14AWG) runs to a relay, as well as the normal + switched lead from the fuse panel, and then from the relay to the fan. The webasto bus controls the triggers of the relay. When the Webasto is off, the + feed runs from the Defender fuse panel, through the relay to the fan + lead. That when the fan is running slow on hi. When the Webasto is on, it triggers the relay to closed, and the power flows now from the Webasto battery lead to the heater fan-double the output (running at a normal cars speed). Using jumpers to bypass the relay, I was able to figure out, that it really comes down to the 16AWG factory lead to the heater, just like the factory headlight configuration.
To increase the current flow, I split the Webasto + lead to the relay into two, with the other split going to a 2nd relay and that relay is triggered by the original heater + lead. Now, when the accessory switch is on, the fan gets the Webasto battery lead without the Webasto being on. Tested today on a cold morning, for the very first time, I got hi output heat from my heater, enough to feel a solid burst of air flow hitting my legs through the under dash AC heater duct. With this turn of events, I don't feel I even need a fan upgrade now.
I just wish I had realized this earlier. The bottom line is the OEM heater needs a wiring upgrade just like the headlights, with the OEM wire becoming the trigger to a relay, and the heater receiving a 14AWG minimum direct (but fused) feed from the battery. The results are impressive for very little effort.
Mark Kellgren
KM4BOR
Old April 27th, 2013, 11:38 AM
The stock wiring should not be restricting power to the fan, at least from my own testing. You might have a bad heater switch or something else in the circuit causing a problem.
Old April 27th, 2013, 12:14 PM
well no problem now!
Mark Kellgren
KM4BOR
Old April 27th, 2013, 12:21 PM
yes! wiring change was post port widening. before Hi speed is now my after Low speed-literally. may be that 16 awg was just enough in a new harness, and with age the resistance increases to sub par
Mark Kellgren
KM4BOR
Old April 27th, 2013, 12:49 PM
BTW, in the fall, before this switched positive upgrade last week, I did a full diagnostic on the heater switch wiring (the ground feed through the switch). This included pulling the switch and doing a full cleaning with electrical cleaner on it, as well as replacing the black wire (with 14awg) going from the switch to the heater, and from the switch to chassis ground. After that work, I tested no ohms through the earth circuit on hi speed. so if there was residual resistance it was from fuse panel to heater.
I can say for sure that a 14awg upgrade to both pos and neg leads was a significant performance increase for me.
Mark Kellgren
KM4BOR
Old April 27th, 2013, 01:33 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
That's good info Mark, thank you.
Old December 10th, 2013, 02:06 PM
BlackField's Avatar
BlackField
Oscar
D110
Subscribed awesome stuff.
Old December 19th, 2013, 07:31 AM
As an update, I'm going to be doing the DefenderVent install so I now plan on doing the heater blower fan upgrade in the spring. I'll post up then if the Autozone PM137 2 pole blower will fit. Of course, if someone else plans to do this upgrade in advance of that, by all means let us know what part works.
Mark Kellgren
KM4BOR
Old March 9th, 2014, 05:23 PM
Another update. Being so nice here finally in charlotte, I decided to look into a recent loss of blower strength over last 2 months. I suspected heat air was leaking in places. I went to drop the AC facia, and that's when I notice that I left the mounting screws loose, allowing a huge gap around the lower foams seals between AC and heater duct. Ok. So the I turned on my heater with AC dropped and WOW the blower was really kicking with the wiring mod I made previously. I tightened everything up and that is when I noticed the huge drop in blower strength when it passes through the AC. So time to investigate. Examining the actual duct face on the AC, I notice that it is only about a 1.5 inch hole - significantly smaller that the actual heater duct! It was the bulkhead mod all over again. They made it small for that pathetic little square foam seal. So I ripped it off, dremeled the top off to open it up, and added foam seal around it on both heater side and AC side. Huge improvement in blower pressure!
Mark Kellgren
KM4BOR
Old September 4th, 2014, 06:22 PM
Jaded-7
Harrison
Just wanted to add additional info here. Fan PM137 works on RHD defenders. Just had to swap the cage for the counter clockwise fan that was on the car, and wire it up accordingly.
Harrison
Old December 18th, 2014, 10:14 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Mark, did you end up using pm137? I'm about to do this and not clear on which one to buy.
Old December 18th, 2014, 10:15 AM
not yet take the lead!
Mark Kellgren
KM4BOR
Old December 19th, 2014, 10:13 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Mark c'mon man, we can do this. let's make a pact to do all our heater upgrades by 2017?
Old February 18th, 2016, 01:45 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
just started on this wonderful journey...and I gather from John/Jason et al that the bulkhead opening needs an additional 2" to the pass side- correct?
I have a bare bulkhead right now so I want to get this out of the way while it's easy to cut and access!
Rent my
90, d-90, fan, heater, nas
'93 NAS D110 AC Condenser Fan Jon_Winningham Wanted 19 January 17th, 2015 11:49 AM
1997 Defender 90 NAS Station Wagon, Coniston Green, Galvanized Frame 74k miles Boone90 For Sale - Vehicles 24 September 15th, 2012 10:59 PM
FS used NAS 90 frame ECR The Vendors Loft 2 March 28th, 2011 08:42 AM
Safety Devices NAS 90 Roof Racks ECR The Vendors Loft 47 September 14th, 2010 09:28 PM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
