heater fan testing - Defender Source
Old January 22nd, 2011, 03:22 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
heater fan testing
My heater fan appears to have died but I need to confirm this 100% before going after a warranty replacement. What is the best way to do this?
If I short at the switch to ground nothing happens, I am not 100% on how the rest works and have limited spare fuses with me, but given I am driving every day the lack of heat is getting annoying.
Old January 22nd, 2011, 04:13 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
A defender warranty? Wow!
Old January 22nd, 2011, 11:42 PM
Stick something in through the intake and make sure it turns freely. They get easily jambed with dirt or ice.
Old January 23rd, 2011, 12:26 AM
ajh
Andrew J. Hutton
I'll see if I can get to it tomorrow, I do run a snow guard though and I have been in New Mexico for a week now so probably not ice.
Old January 23rd, 2011, 12:51 PM
michael67's Avatar
michael67
Michael White
110 Tdi
You should be able to turn the fan by hand (with the power off, of course) by sticking your hand into the air inlet. If not, try soaking the fan area the best you can with some sort of break-free type spray (e.g. WD-40). If it still doesn't move, say "Hello" to cold legs
If the does move, you can try shorting the switch connectors to ground. This is fairly high current, so use some jumper wires; don't short it by hand. If the fan spins, you may have a bad switch or a bad ground wire on the switch.
Old January 24th, 2011, 05:58 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Have you scanned the fuses yet? Check for the fuse(30 amp) piggy-backed on top of the heater box itself under hood. Why that fuse loves to blow after it's been sitting and we get a cold spell I don't know...but they do!
Old January 24th, 2011, 09:03 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Just unplug the connecter to the fan motor (its on the top left corner on a 94 D90 and its black). I just disconnected mine when I took out the box for the new heater core last weekend. Then to test, stick some - & + wires into the connectors and see if it spins. Then you'll know for sure if it works.
Robert Deniro
fan, heater
Heater fan amp draw Overlander Defender Technical Discussions 1 April 3rd, 2010 10:12 AM
Heater fan lever broke...in a blizzard chris snell Defender Technical Discussions 8 January 8th, 2007 05:52 PM
Dead Heater Fan chris snell Defender Technical Discussions 4 January 25th, 2006 11:07 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
