Heater fan control - Defender Source
Old October 16th, 2012, 08:31 PM
egor
kody martin
1986 Land Rover 90
Heater fan control
Have a 1986 90.
Noticed that my fan control makes three clicks. All three are around an inch from the bottom. The actual fan doesnt kick on until the last click at the far bottom.
Once set to the far bottom position the fan is pretty strong.
If I follow the cable to the engine compartment, can I make adjustments? Or can the fan controller behind the gauges be adjusted.
Not sure if this is how they all work. Just didnt want to waste time trying to adjust a fan control that is working properly.
Old October 16th, 2012, 09:15 PM
amityd90 had a great write up on it last year - heater cable or something like that is probably a good search to start with.
Old October 17th, 2012, 01:01 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Come on, Encyclopedia Brown. Let's see a link.
Old October 17th, 2012, 01:15 AM
bjf's Avatar
bjf
barry f
94 ST #395
What fun would posting a link be? The super user prefers to chastise users who ask questions that were possibly answered in 1987 again.
Old October 17th, 2012, 08:01 AM
It's best to pass along the skills. Go to advanced search and search heat cable by AmityD90 and it should come up.
Old October 17th, 2012, 08:32 AM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
http://www.defendersource.com/forum/...ad.php?t=28843
May not apply to older defender
Old October 17th, 2012, 08:53 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
if you have high speed only it would be a bad blower resistor .........
Count down to 7000 posts ...you can do it Josh!
No Mall crawler here
Old October 17th, 2012, 09:01 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Where would you find the blower resistor?
Old October 17th, 2012, 09:07 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
depend on the unit behind the switch assembly or near the blower motor + wire .. power runs through it and regulates the speeds when it goes bad there is no resistance so you get high speed only ..
ill run outside and check have 2 D90 here with ac
------ Follow up post added October 17th, 2012 05:15 AM ------
the 97 has factory a/c ..looks like it has a electronic blower module between the fan assembly...the 94 has a different unit cant see the blower unit right now should be a ceramic resistor in the blower case somewhere with 3 or 4 wires attached to it
Old October 17th, 2012, 09:27 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
my bad i did a josh and jumped into the conversation without actually reading from the top.....
the cable controls the heat temp regulates the incoming air to the matrix .. the switch is has a internal resistor that regulates the power to the blower for speeds ....
sorry for the confusion ran out of coffee this morning .....off to check out a d90 with 20k on it ..
Old October 17th, 2012, 09:37 AM
Well, it always seems to take you 3 posts to get the answer right, so you'll be at 7k soon enough with all the help you've been giving out lately!
Old October 17th, 2012, 10:01 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
hook line an sinker !
capt quote strikes again .....83 to go
Old October 17th, 2012, 10:36 AM
You don't have a problem until you hit 10k.
fan, heater
Heater fan upgrade in the NAS D-90???? Doc Martin Defender Technical Discussions 134 April 21st, 2017 08:01 AM
Heater fan lever broke...in a blizzard chris snell Defender Technical Discussions 8 January 8th, 2007 05:52 PM
Dead Heater Fan chris snell Defender Technical Discussions 4 January 25th, 2006 11:07 PM
Hot/Cold - Blue/Red Heater control cover SFD90 Defender Technical Discussions 5 October 21st, 2003 06:31 PM
