Heater core blew up - Defender Source
Old May 27th, 2016, 08:56 AM
Heater core blew up
Driving in to the office this morning in the Loob. Just as I was getting to the Zoo the core let go spewing all over my shoes and making the inside of the truck a cappuccino machine.
Fortunately the 7 Eleven across the street from the Zoo entrance had anti freeze (!) and water, so only a short walk to get help. Ran a bypass hose on the heater pipes and got back under way.
Now it seems to be running hot. I guess I still have an air pocket somewhere and it's cavitating the water pump? Dunno.
Carpets soaked,
Old May 27th, 2016, 09:15 AM
You need to burp the cooling system to evacuate the air.
And its time for you to enter "The Matrix".
Old May 27th, 2016, 09:38 AM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
Happened to me in my '94 SWB this time last year in Moab ..... on the same street as the NAPA ... and the liquor store. Fortune kicked me in the butt, but was smiling when doing so.
Old May 27th, 2016, 09:42 AM
That job is a mother as you could tell from the pictures I sent you last winter.
The heater core and blower motor package deal from AB is the way to go. The close to 60 pages of instructions
on how to do the job help. You do not have to remove the drivers door or steering columns , but pretty much everything else does have to come out.
My daughter sent me a text that she had to add coolant to mine, I'm afraid the same is about to happen.
The biggest pain was getting the 5 different flap valves to all seat back properly when putting the two halves of the heater box back together.
There are two in the very middle of the box that gave me hell for hours
Old May 27th, 2016, 09:45 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
That sucks... at least you have 4-6 months before winter returns. They can be a pain to get all the air out.
After parting out my old classic, I think LR built the whole thing around the heater core. Basically the whole dash has to come out to get to it.
Old May 27th, 2016, 10:30 AM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
I have to do this job as well on my '92...
And I remember that Rob also has a similar job on his project truck (unless he already did it).
Ours are just frozen blower motors though... but might as well do the core while we are at it.
I vote a wrenching weekend at his barn, to fix all 3 trucks. ha
1984 Camel Trophy 110
1995 Range Rover Classic SWB
1992 Range Rover Classic SWB
Old May 27th, 2016, 10:56 AM
Yup, not a fun chore. I have a couple heater units floating around and a brand new core someplace...
Old May 27th, 2016, 11:18 AM
If you can do three in a weekend you are a better man than I.
Just the retrofit of the aftermarket heater motor takes some careful modification of the plastic heater box and then putting it back together with the new core was hours.
Not a difficult job just a slow meticulous one
Old May 27th, 2016, 11:29 AM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
And... the location just changed to Dougs barn. ha
Just clarifying, I wasn't suggestion I would change all 3, ha. 3 people, 3 trucks.. at the same time.
Old May 27th, 2016, 12:03 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
The earlier heater boxes are better (steel). When the core in my 1990 shit the bed, I put the box and rebuilt box and core from an 87 in there. The foam on the flapper doors was deter primates, so I replaced the foam with closed cell foam and it sealed much better. Because the core in a RRC is constant flow, air leaks in the box will result in a warm cabin.
-Jeff
If it wasn't such a PITA, I would love to pull mine & recondition it. So much air flows through it which is both anoying in the summer & the winter. I have one pulled from my old '88 that I should recondition for when the time comes.
Old May 27th, 2016, 01:33 PM
Sorry about the heater core. Not a dig at you at all Bill, but you gotta love those "bargain" RRCs with 100K+ miles and ticking time bombs under the hood and behind the dash. But every CB thinks you can spend $4k+ on fixing all that stuff and the truck is somehow still only worth $2500. Lol...
If the coolant looked like something you get at Starbucks, then perhaps there are other problems. I can bring the block tester kit over if you want.
When did you start working at the Zoo?
Carpets soaked,
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 27th, 2016, 03:58 PM
Ok it's overheating with the heater hose bypassed
Old May 27th, 2016, 04:03 PM
Did you bleed it? Did you pump the upper rad hose to make sure it is full of coolant? Did you fill the radiator directly through the plug on top?
If so, you have other issues.
Old May 27th, 2016, 04:16 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Hope that you still have air in the system..... if not probably HG & the heater core was the weak link.
When bleeding the air from the coolant, I use a tall funnel with a threaded piece of pvc epoxied on & attaches to the rad making it the highest point. Sometimes I raise the front right corner too to help.
Old May 27th, 2016, 04:59 PM
Yeh I'm filling from the top. I'm limping home now stopped for a cool down now.
Old May 28th, 2016, 06:04 AM
Further investigation will probably confirm that this truck is dead. I don't think I'm going to do the repairs on it.
Old May 28th, 2016, 06:25 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Damn, sorry to hear that Bill. We're fluids fresh and temps normal otherwise?
Old May 28th, 2016, 08:55 AM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
That's bad news and I definitely feel your pain. My SWB is in for a headgasket replacement.
heater
Blew u-joint in rear, help on 4 bolts removal on brake drum UpnOver Defender Technical Discussions 3 February 2nd, 2012 07:53 PM
heater matrix heater core. Naplm00 Wanted 0 December 21st, 2011 01:34 AM
I blew up my tranny, time to work Neil McCauley Defender Technical Discussions 3 August 2nd, 2008 08:35 AM
Looks like my 300 TDi head gasket blew again cdb Defender Technical Discussions 6 July 2nd, 2008 08:27 PM
Help blew my transfer seal ron Defender Technical Discussions 23 November 15th, 2006 01:31 AM
