Heater Core and Box Question - Defender Source
Old July 20th, 2016, 01:05 AM
RBBailey
RBBailey
1965 IIa
OK, I'm confused, I could swear I was told by some on this site, at a local shop, and by some other people more experienced than I, that the heater core with the down turned pipes would fit a LHD heater box. But I can't begin to make it fit. There is a bulkhead/divider in there that would need to be at least 1.5 inches further over to one side to allow this core to slide into the box.
Not a big deal, just means I need to order a straight pipe core after all. So.... when I look on Rovahfarm, it says:
Application: Defender LHD and RHD heater matrix to WA159800 - from XA159807 only RHD - horizontal pipes
Not sure how to interpret this to get the one I need for the box I have. I don't know what year Defender this box came from.
Project:
1965 IIa SWB
Old July 20th, 2016, 01:30 AM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
Originally Posted by RBBailey View Post
OK, I'm confused, I could swear I was told by some on this site, at a local shop, and by some other people more experienced than I, that the heater core with the down turned pipes would fit a LHD heater box. But I can't begin to make it fit. There is a bulkhead/divider in there that would need to be at least 1.5 inches further over to one side to allow this core to slide into the box. Not a big deal, just means I need to order a straight pipe core after all. So.... when I look on Rovahfarm, it says: Not sure how to interpret this to get the one I need for the box I have. I don't know what year Defender this box came from.
have you talked to Trevor at Rovahfarm? He should know what you need. I have sent him a picture when I could not explain what I needed.
Old July 20th, 2016, 02:00 AM
RBBailey
RBBailey
1965 IIa
Plan to in the morning.
Project:
1965 IIa SWB
Old July 20th, 2016, 08:11 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I think it also depends upon the year of the heater box. Some of the older trucks I have seen run with the down turned pipes. I have seen some of the newer 300 and Td5 boxes use the straight out pipes. The size of the cores are different.
Land Rover 110
heater
Heater Core Question RBBailey Defender Technical Discussions 0 September 5th, 2015 12:59 AM
Wanted - Smiths Heater Core and Housing Contractor Wanted 9 February 5th, 2015 04:06 PM
93 RRC heater core question Mtanzania Defender Technical Discussions 2 January 5th, 2014 10:25 PM
heater matrix heater core. Naplm00 Wanted 0 December 21st, 2011 01:34 AM
Early and late heater core / matrix Naplm00 Defender Technical Discussions 5 April 13th, 2011 08:48 PM
