Heater controls - Defender Source
Old November 24th, 2005, 11:32 AM
jracenstein
Jeffrey Racenstein
Heater controls
the control knob that adjusts the air temperature in my '94 defefender is stuck in the up position (Cold) Has anyone had this happend and how hard is it to fix? I like working on the truck but am certainly no expert. Thanks in advance
Jeff
Old November 24th, 2005, 12:20 PM
Probally not to bad, nothing more than a frozen heater cable, the go across the firewall to the box on the passengerside firewall, does the lever move?
Old November 24th, 2005, 12:36 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Mine does that once in a while, usually just a good yank gets it unstuck,
-Hans
My oil line fix
My 100k stopped odometer fix
stevewhitaker's Avatar
stevewhitaker
Stephen Whitaker
1994 D-90
When mine did the same thing I was able to take out the screws that hold the plastic piece that covers the levers and then slightly tweak the levers so they don't jam each other, check the cables, lube them, and put things back together. It was about a half hour job. I have not had a problem since.
Old November 24th, 2005, 01:16 PM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
follow STephens advice and it will be sorted
Old March 9th, 2006, 11:59 PM
proulx70's Avatar
proulx70
Paul S.
1997 NAS BRG Soft-Top
Found the Answer: Pics included
It turns out that there is a spring-loaded pin that 'clicks' into a slot in the up position. On mine, I noticed that the slot had been worn into a sharper angle than it should have so the pin would hit the "wall" instead of sliding up the slope when pressure was applied. I took a file and ground down the slope to make it smoother and more gradual. Afterwards I used some Land Rover clear touch up paint sealer to coat the metal a couple of times as it's really hard to get sandpaper in there to smooth it out. Finally, I oiled the spring and pushed it in fully a bunch of times to make sure it hadn't seized.
No need to be a mechanic for this. All you need is a Philips head screwdriver, a file and some oil.
Works like a charm now and still 'clicks'!
Best to all.
Paul
Name:	Heater Control 1.jpg
ID:	5193   Click image for larger version
Name:	Heater Control 2.jpg
Old March 10th, 2006, 09:59 AM
Jase
Jase
pending
Best to all.
Paul
Had a similar issue with my control level. I added a little oil about a year ago and have not had an issue since.
Old March 10th, 2006, 10:30 AM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
l
CvC had the same thing on his. I opened it up and we ground it down a bit with the ol' Dremel. Good as new. He was happy to have heat in these chilly chilly Texas winters. I can see why, it's only going to be 83 here today and like 88 tomorrow.
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
heater
heater controls tomaco1 Wanted 0 September 26th, 2008 08:14 AM
New heater controls? tomaco1 Defender Technical Discussions 0 September 19th, 2008 06:47 PM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
