Heater Cables Sticking - Defender Source
Old October 20th, 2003, 04:11 PM
mgrgpg
Mark
1989 D110
My heater blower lever sticks, and am assuming that it is the cable that is sticking. Is there a way to lubricate them?...Same problem but not as bad with the control lever that regulates if the air comes out the top vents or the bottom vents.
Mark
Old October 21st, 2003, 03:37 AM
greg_sikes
Greg Sikes
1997 D-90 SW #0433
Mark,
I had similar problem. I took the dashpanels off that covered the different levers/cables and then used a lubricant (spray can with "straw" attachment). A quick squirt, then worked the lever a bit until its movement was tolerable.
Greg
heater
heater cables tomaco1 Defender Technical Discussions 0 September 20th, 2008 07:46 AM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
Rear Window Heater Help mwmcgehee Defender Technical Discussions 0 August 21st, 2004 01:40 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
