Heater Cable Fastener (trunnion) ? - Defender Source
Old May 10th, 2010, 01:33 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
doing LHD conversion.
on the 'new' lhd heater(could be a TD5 heater), the upper damper has the traditional connectrion to the control wire (uses the barrel 'trunnion' to grab the cable. So the lever arm has two blades with a hole through each for the trunnion barrel).
For lever on the side (air flow on/off), the control arm is just a pin (not two blades with a hole for a trunnion barrel). Anyone know how or what is used to attach to the control wire to this arm?
Otherwise, I'll try prying the old arm off my RHD heater
thanks
heater
Cable on heater box atlawson Defender Technical Discussions 2 January 17th, 2008 04:22 PM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
