Heater Box Restoration / Info - Defender Source
Old September 27th, 2015, 08:10 PM
This thread covers restoration of my original RHD heater box. I believe NAS heater boxes work in an identical manner.
I'll jump ahead to some diagrams showing how the internals of the heater box work, for informational purposes.
There are two internal flaps which control the routing of the air in the heater box.
The vertical flap controls whether the air flows through or around the heater core.
The horizontal flap controls how much of the air flows out of the heater box. The blower motor on the heater only has two speeds:
1. full blast
2. imperceptibly slow
I believe this is used as a primitive form of fine velocity control on the heater box when operating in full blast mode.
The heater box was acid dipped, bead blasted, and then powdercoated in BBS Gold.
ID:	130943   Click image for larger version
Old September 27th, 2015, 08:23 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Always wondered what happened in the black box!
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old September 27th, 2015, 09:25 PM
Very cool and nice work....thanks for sharing
Old September 27th, 2015, 11:21 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
What is really cool about the heater design is that it can be flip-flopped to work on either side. My guess is after the pieces were stamped out of sheet steel it would be folded/bent/pop rivet/spot welded a certain way depending on if it was being made for a LHD or RHD vehicle. The blower fan housing is specific left to right tho.
Also - there is a different heater core design and probably a change in the box as well. Not sure what year they went from the down in/outlets to the horizontals in/outlets.
And those added graphics are sweet sonoronos!
Old October 4th, 2015, 05:59 AM
Installed the replacement gm fan.
All old part numbers listed on the web seemed to fail to find a part at autozone, Napa, advance, etc.
New part is interchange for a 1994 Buick Century, V6. Attached is the part I got from advance auto parts.
The rest of the install instructions are identical to that provided in the thread where lav did his heater upgrade.
Old October 4th, 2015, 09:35 AM
Heater box vent flap foam used is 1/4" heat-resistant EPDM 2.5psi closed-cell foam, with a 215 degree maximum temperature.
I recommend anyone else replacing the vent flap foam to use 1/8" foam in the future.
Old October 4th, 2015, 10:14 AM
1. full blast
I assumed it was you close off the flow when you don't want air from the outside, like when wading, or it is hot out.
At least on mine, I thought the speeds were well chosen. About 50% of the heat output and air flow on the low speed. 78 cfm low speed, 149 cfm high speed.
Old October 4th, 2015, 03:05 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Mine does not blow at all, I suppose I will start checking. I suppose I start with see if the fan is turning freely then electricity gets to it?
Thanks for sharing this.
Old October 4th, 2015, 04:49 PM
Its possible. One strange thing is that it doesnt actually appear to be physically possible for the horizontal flap to close completely using the push-pull cable.
So whatever the purpose of the flap is, it has to do it always partially or fully open.
Out of curiosity, do puma trucks even have a heater box? Or is it for an ac evaporator only?
Old October 4th, 2015, 06:00 PM
It should close fully. Mine did.
Old October 4th, 2015, 06:54 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Blower is in the engine bay, heater box & A/C evap (I think) is behind the centre console. That's why it sticks so far into the cabin... got to pack all that stuff some where.
Name:	Puma heater.jpg
Old October 4th, 2015, 08:43 PM
I will double check mine
Old October 4th, 2015, 10:09 PM
DailyDrivenDefende
Michael
Not Defender related but my old Jeep had a heater box that once it is bolted in, it changes the dimension of the box ever so slightly the operation of the blend door became rather snug.
Old October 21st, 2015, 04:22 PM
Some photos after the restoration.
New bulkhead seal arrived so it's finally finished.
ID:	132923   Click image for larger version
ID:	132925   Click image for larger version
Old October 21st, 2015, 11:05 PM
DailyDrivenDefende
Michael
Very nice! Did you replace the resistor? Did you re-riveted everything? Any surprises as you were doing this restoration?
Old October 23rd, 2015, 10:33 AM
Thanks! I kept the original resistor, as it seemed to work OK
Old October 23rd, 2015, 05:05 PM
I received some questions regarding the GM fan upgrade, and really this thread has the most information on the topic - courtesy of Nathanwind:
http://www.defendersource.com/forum/...0-a-38561.html
I think the only things I can add are:
1. The GM blower motor comes with a LHD blower cage. If you have a RHD truck, save your original RHD blower cage.
2. The GM blower motor is wired for LHD blower operation. If you have a RHD truck, you must reverse the wires to reverse the direction of the blower motor.
3. You must open the motor on the GM blower by drilling out 3 rivets.
4. You must remove the ground wire riveted onto the blower motor housing.
5. You must hammer flat the raised lip around the periphery of the blower motor housing.
6. You must drill at least one new hole in the periphery to allow the GM blower motor housing to bolt to the Defender fan box.
Old March 14th, 2016, 10:40 PM
Tom1090's Avatar
Tom1090
Tom Schuler
1988 Defender 90
Question Heater control cables?
OK, so this is a dumb question, but I have a loose cable on top of my heater box. I have an 88 LR90 NAD. The hot/cold cable seems to be connected to the top of the heater box and works fine. The windshield/floor director control also seems to be fine. Airflow seems to have two fan speeds: slow and fast. What should this other cable connect? It seems to be actuated by the fan speed cable.....
Old March 15th, 2016, 12:02 AM
DailyDrivenDefende
Michael
Whatba timely thread revival, where did you source the heater core Sonoros? Any recommendation? RHD it has the turnes down heater core pipes.
Old October 15th, 2016, 01:26 PM
Sorry I never got back to you, Michael. I never got a notice that you asked a question on the thread, and I apologize.
I sourced the heater core from Rovahfarm, part number AAP817.
restoration, heater
*Rare* NAS 110 AC/Heater Assemblies For sale or trade for D90 heater/dash conversion evilfij For Sale - Parts 10 May 2nd, 2013 04:39 PM
heater matrix heater core. Naplm00 Wanted 0 December 21st, 2011 01:34 AM
200tdi block heater vs hose heater tomaco1 Defender Technical Discussions 14 December 7th, 2009 10:55 AM
Safari Cage Restoration Advice mattarm Defender Technical Discussions 17 September 7th, 2007 11:29 AM
Rear tub restoration question Hoosier Defender Technical Discussions 1 September 5th, 2006 08:29 AM
