Heater Box removal help NAS 90 - Defender Source
Old November 29th, 2015, 07:26 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
I am trying to pull my heater box and replace the fan on my 94 NAS 90. Mine has A/C, I have pulled the section that has the vents off. Loosened the top of the A/C unit and pushed it down some. I cannot see the 4 bolts that should be holding it on. I have searched the threads and cannot find any insight.
I am sure that I am doing something wrong. Can someone point me in the right direction.
Old November 29th, 2015, 07:49 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I had to replace the heater core in my truck a couple of years ago, and as I remember the bottom 2 bolts were behind the AC duct, and the top 2 were behind the dash. Then there was some contortions required to actually pull the heater unit. Once I had the thing out, I installed riv-nuts so I would not have to take all the dash bits off the next time. Good luck, I am sure others will chime in.
Angus
Angus
Old November 29th, 2015, 07:57 PM
gwmckee
George
1994 NAS D90 #1919
Hey Jason - are you replacing the fan for the heater or the A/C? I replaced the blower on my NAS D90 this summer and essentially pulled out the entire unit in the passenger compartment. It was a pain but the plate that the blower attaches to was way rusted so it gave me a good excuse to clean and paint it. I can send pictures if you want. The new blower I bought from SPAL USA is great.
Good Luck!
Old November 29th, 2015, 08:07 PM
Jbullis's Avatar
Jbullis
Jason Bullis
Did you have to drop the A/C unit?
Angus
Old November 29th, 2015, 08:09 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Yep. That was the only way to get at the nuts. That is why the riv-nuts on re-assembly.
Angus
Angus
Old November 29th, 2015, 10:24 PM
CDeWan
Clay DeWan
5.3L beastie
look for the thread on cutting the bulkhead to get more air flow out of the heater box. Simple trick. the heater box is a pain in the arse. if you do find the two that bolts that go through the heater box mount from the engine bay. Fix a vice grip on them and get them from the top side. Don't forge your foam between the box and the bulkhead maybe all disintegrated on install.
90, heater, nas
NAS D110 Heater Core Removal Jon_Winningham Defender Technical Discussions 6 January 8th, 2014 11:23 PM
*Rare* NAS 110 AC/Heater Assemblies For sale or trade for D90 heater/dash conversion evilfij For Sale - Parts 10 May 2nd, 2013 04:39 PM
Cigar Lighter Removal and Rear Wiper Switch Removal isleofbones Defender Technical Discussions 6 April 13th, 2013 08:02 PM
NAS D110 Heater Core Removal Stmpede Defender Technical Discussions 10 April 7th, 2012 01:54 PM
Easy heater removal ??? artm Defender Technical Discussions 1 October 10th, 2003 08:27 AM
