Heater box mounts for '94 - Defender Source
Old February 24th, 2012, 06:42 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
Could somone with a '94 have a look at the heater box and tell me how it's mounted to the bulkhead. I can see the 2 x 8mm bolts at the top, but it looks like it should also be bolted at the bottom? My new bulkhead doesn't have holes where I think it should, so wanted to check before I start drilling!
Old February 25th, 2012, 06:05 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
I believe there should be two small bolts on the bottom too, though I can't remember what size. They can't really be seen without a mirror if you have an A/C setup in your truck.
Old February 27th, 2012, 09:08 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
Thanks. I figured there'd be something holding it on at the bottom. Can you tell if there is any kind of gasket material where it contacts the bulkhead or is it pain-on-paint?
Old February 27th, 2012, 07:45 PM
Turbofan's Avatar
Turbofan
Ethan
I don't think there is anything special going on there. Plug and play.
Old March 3rd, 2012, 09:51 AM
red&yellowrovers's Avatar
red&yellowrovers
Joe Still
95 D90 NAS 3.9l ST AA Yellow #2719
Foam seal between bulkhead and box. Mine is apart, need a pic?
Old March 3rd, 2012, 10:28 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
I think I got it now, thanks though. I have the foam seal at the top where it goes through the bulkhead, it was at the bottom where it rests on the bulkhead that I wasn't clear on. I ended up drilling 2 x 6mm holes in the bulkhead and made a thin rubber gasket to stop any paint-on-paint rubbing causing problems later.
I was tempted to enlarge the hole in the bulkhead as discussed elsewhere on the forum but decided that's probably not the real source of the restriction. The knee vents in the plenum chamber are much smaller and will probably determine the amount of air entering the cabin.
Old March 3rd, 2012, 11:28 AM
red&yellowrovers
Joe Still
Sound reasoning.
heater, mount
The "Increase your heater output" thread Overlander Defender Technical Discussions 25 February 28th, 2012 06:42 PM
Wanted: Heater box red64chevelle Wanted 11 February 13th, 2012 01:06 AM
RHD Blower motor or Heater box Jymmiejamz Wanted 2 February 9th, 2012 10:23 PM
LHD heater box rayfi For Sale - Parts 2 February 4th, 2011 04:54 PM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
