heater box foam - Defender Source
Old August 27th, 2013, 06:00 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
heater box foam
Disassembled dash including lower part for clean-up and sorting of wiring. Attached is a picture of the outlet vent of the heater core/box. Airflow is controlled by a flap. This flap appears to be insulated with a foam material, which is crumbling. Can anyone suggest a replacement source for this foam, preferably with self-adhesive on the back. Looking for direct links, actual part #'s.
Old August 27th, 2013, 06:16 PM
Did you search heater box foam on here? You can also call Rovers North or the like and they can help even without a part number.
Old August 27th, 2013, 07:30 PM
CaptMidnite
Daniel Choi
heater box foam
Already did that. "heater foam" pulls up threads about the heater box. The Rovers North catalog lists the whole heaterbox assembly. Will call them tmrw. I have a feeling this repair will entail sourcing foam from a crafts supply store and cutting and gluing it.
Old August 27th, 2013, 09:22 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I went to Lowe's And picked up some foam material. I had to spray sticky on it but it did the trick.
Old August 28th, 2013, 10:50 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
While you're at it you may want to look at the lower heater vents in the dash. The flaps that cover the holes so the air is directed up through the defroster vents also has that foam on them. the foam was totally gone on mine so you could never fully block the vents off making for hot feet in the summer and inefficient defroster performance. Keep us posted on what you end up using
Old August 28th, 2013, 12:44 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Go to your local commercial HVAC outlet & get some 1/8" x 1/2" closed cell ducting gasket. It's self adhesive, sticks like the proverbial and won't soak up water. Use that to put a strip round the edge of the flap where it contacts the body of the heater. Also works well on sealing up gaps around seat boxes etc... and it's cheap too
heater
Heater box mounts for '94 MAX711 Defender Technical Discussions 6 March 3rd, 2012 11:28 AM
The "Increase your heater output" thread Overlander Defender Technical Discussions 25 February 28th, 2012 06:42 PM
Wanted: Heater box red64chevelle Wanted 11 February 13th, 2012 01:06 AM
RHD Blower motor or Heater box Jymmiejamz Wanted 2 February 9th, 2012 10:23 PM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
