Heater Blower - Defender Source
Old October 6th, 2010, 03:24 PM
PDX Bolt
Tom Harbolt
1995 White D90 Soft Top
Heater Blower
The lever suggests that the blower will blow at multiple speeds. Mine only blows at the highest speed. As the lever clicks down to the highest speed nothing happens until it gets to the highest setting. Any advice on what this might be? How many speeds should it blow at?
Old October 6th, 2010, 03:35 PM
matansas
jon lyons
97 AA Convertible
heater
your not alone, however saturday i thought it ran slow for a little while
Old October 6th, 2010, 03:55 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
tracing out the circuit:
there should be a connector(connectors) under the hood near the blower) wih Purple/green, Green/Yellow, and Green/Slate wires.
Disconnected, Purple/Green from the dash/bulkhead (not going to the blower) should have 12VDC (to a good ground) with ignition on.
Green/Slate should be zero resistance to ground with dash switch in high speed (second click)
Green/Yellow should be zero resistance to ground with dash switch in Low speed (first click) - if not, the switch has an issue - if ground is good in this setting, switch is good and the low speed resistor is probably shot.
The resistor is mounted in the blower housing (riveted in on a plate IIRC). Resistance should be read between Purple/green and Green/Yellow through the disconnected blower connector. If not, that resistor is probably shot.
heater
New D90 Owner - Heater blower install RoverNC Smaller Projects 2 February 18th, 2010 09:10 AM
Heater blower and broken 02 sensor for 94 d90 budz Wanted 0 November 12th, 2009 08:47 PM
replacement heater blower motor grnrvrs Defender Technical Discussions 4 March 5th, 2009 09:08 PM
1983 RHD Heater Blower Switch Part Number newfD90 Defender Technical Discussions 5 November 20th, 2008 02:38 PM
Need help with heater blower motor! Firefighter2904 Defender Technical Discussions 27 October 15th, 2007 09:51 AM
