Heater amp's - Defender Source
Old September 22nd, 2014, 03:41 PM
scrubs
henery
1974
Heater amp's
Hi all, After replacing the amp gauge I noticed that the heater ,when on, draws the guage down to 11 ish amp's from 13.5(100amp alt) and wondering if this is normal? Never knew what it was before due to no working guage
did call a popular tech line only to be left feeling like a idiot from a smart a#s kid who couldn't answer the question
Old September 22nd, 2014, 03:46 PM
It should not pull the voltage down that far. I suspect your battery is bad. If you are not really knowledgeable with electrical, I would get the battery and alternator tested at an auto electrical shop. Seeing as you are calling volts amps, I'm guessing that would be a good plan ...
Old September 22nd, 2014, 04:24 PM
sorry about delay in your pm. yes, you should not see a drop below 13. volts at all from the heater. The heater is grounded through the switch, but has a straight positive lead to the heater fan. if you have a bunch of funky wiring, you could see some weird stuff if the voltmeter has custom wiring and sharing with the heater. check against OEM wiring diagram. and yes, if your battery is shot, it won't have the capacity to moderate the amp draw. but i suspect this is a ground issue on the gauge or heater since you didn't mention other battery related issues like starting and such.
Mark Kellgren
KM4BOR
Old September 22nd, 2014, 05:08 PM
scrubs
henery
1974
Thanks for replies,will start with switch,batteries are new.
Also having ignition/key issues,every other bump shuts electrical off, have new one ordered
Old September 22nd, 2014, 05:17 PM
that clarifies the issue. this isn't about your battery or alternator at all. you have some bad connections. disconnects are causing your positive path to find alternate paths through smaller gauge wires and causing voltage issues at different terminal points.
Mark Kellgren
KM4BOR
heater
*Rare* NAS 110 AC/Heater Assemblies For sale or trade for D90 heater/dash conversion evilfij For Sale - Parts 10 May 2nd, 2013 04:39 PM
heater matrix heater core. Naplm00 Wanted 0 December 21st, 2011 01:34 AM
200tdi block heater vs hose heater tomaco1 Defender Technical Discussions 14 December 7th, 2009 10:55 AM
MISC & RHD heater parts - for sale or trade Tawayama For Sale - Parts 7 October 23rd, 2006 06:16 PM
Heater core ?? & FYI D90user Defender Technical Discussions 4 October 14th, 2005 03:27 PM
