heater - Defender Source
Old November 24th, 2003, 10:39 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
heater
Hello,
I was wondering if anyone knows how many settings there are on the heater switch. My heat does nothing until about 3/4 of the way down. It then has one more increase at the all the way down location. What do you suggest I check.
Old November 24th, 2003, 10:41 AM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
Mine is the same - 2 settings.
Old November 24th, 2003, 10:53 AM
Campbell's Avatar
Campbell
Rich Campbell
Thanks.
Old November 24th, 2003, 11:22 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Yup, mine is either slightly on, or full blast. I've never really tried messing with the cable attached to the heater in the engine bay, but you might try that. Too many other things on the list to do...
Or just get on of the curtains Art has been selling.
Old November 24th, 2003, 11:56 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Richard. That is normal..
Legend in My Own Mind.
Old November 24th, 2003, 11:58 AM
Campbell's Avatar
Campbell
Rich Campbell
Thanks, just checking.
Old November 24th, 2003, 12:54 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
If I had 20% the power on my heater that the A/C puts out, I'd be happy. My heater goes as follows, setting 1 = nothing, setting 2 = high flow. Weird thing is it comes out of the passenger round vent, that wee little thing, and through every crack in the dash. The rectangular vents get nothing, they seem to be reserved for the a/c which really works. Just I rarely use a/c.
Thank god for the heat through the floor!
I'm contemplating thinking about thinking about it!
Old November 24th, 2003, 01:14 PM
PT94D90's Avatar
PT94D90
Phil
Thumbs up
I know this has been put out before, so forgive me for being redundant, but I experienced a dramatic increase in hot air output after romoving the rectangular vent cover on the driver side.
Old November 24th, 2003, 01:17 PM
paulb's Avatar
paulb
Paul / Boultbee
I think I will play with the vents this long weekend. See what I can do.
Old November 24th, 2003, 01:19 PM
PT94D90's Avatar
PT94D90
Phil
It takes about 30 seconds. It's 2 screws.
Old November 24th, 2003, 02:39 PM
Paul, THe rectangular vents are for the AC only. with the heat on you should get hot air out of the defrosters and the floor vents. you can set the inside control on the left side of the steering wheel to control where the heat goes (defrosters or floor vents). When I set mine for defroster I still get some out the floor vents because my PO dropped a screw in the floor vent, shut the floor vents and bent the door so air always comes out of the floor vents.
I looked behind the dash once and reconnected the defroster hoses a little better but the don't make a very tight fit so you end up with allot of air coming out of the dash.
I have also done like Phil said and removed the floor vent covers and it helped allot. They can be a pain to get to with the AC on but it is still not that hard.
heater
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
Heater hookup TDI Guy Defender Technical Discussions 27 April 19th, 2005 03:16 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
