Heater ? - Defender Source
Old December 15th, 2010, 09:36 PM
Palomino
Rico Palomino
1995 D90 SW #001
Heater ?
It's been a little colder than normal down here in Florida and I have began to realize how much the heater in my D90 SUCKS! I will be traveling north for the first time during the winter and was wondering if the radiator/grill covers help increase the heat. I don't want my family to be frozen while on vacation.
Rico
Old December 15th, 2010, 10:21 PM
huck1974's Avatar
huck1974
shane cates
94 d90
New water pump does wonders. Pull all the crap off that is blocking the flow of the vents. It was 22 today here. Stayed warm with a crappy original soft top from 94.
And hay
And I love you too
Old December 15th, 2010, 11:01 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
It does help get and keep the engine to a proper temp. Other wise it will run a little "cooler". Just make sure that it is cold like high of 35 for the day.
Old December 16th, 2010, 08:35 AM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Check the heat adjustment cable going into the engine bay. If you are blowing cold air, could mean the cable hasn't opened the heat all the way. I thought mine sucked until I checked. Now it blows hot instead of warm.
Old December 16th, 2010, 10:59 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
any chance you can post a pic of what you're talking about? mine could be warmer...
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old December 16th, 2010, 12:42 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Tomorrow morning is the best I can do, but it's pretty simple. The heat level cable goes through the bulkhead and connects to the heat control in the engine bay. The cable connects to a lever that if not pushed (or pulled) - can't remember which direction, - all the way, won't give you max heat. Once I got the heat maxed out, I don't touch the control switch till spring.
Old December 16th, 2010, 12:43 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
no rush at all, I wasn't planning on messing with it anytime soon.
~2008 GTI TSI
Old December 16th, 2010, 02:34 PM
outfield
Steve
1995 D-90 SW #351
My heater was working marginally at best. I changed out the heater core when it started leaking and now the heater works great. The old one was very corroded inside, so not much coolant was circulating through it.
Old December 17th, 2010, 09:25 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Mine was a leaky thermostat causing the engine to never get above 160F, new thermostat and it runs at 195F again and pumps out good heat.
Old December 17th, 2010, 10:03 AM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Here are some picts as requested. The cable sticks and doesn't open up the lever, so it helps to manually extend the line and push the arm all the way out. I read how to do this here and it has helped make the heat output hotter. I've tried to lube the line and assembly to get it to work properly, but still sticks. Sorry for the dirty engine compartment pics. Rausch Creek Mud is a PITA to remove! Also, Waxoyl is a magnet for dust and mud
Still cold when you get in, but that is what seat covers are for. Might invest in some nice sheepskin ones eventually!
ID:	34051   Click image for larger version
ID:	34053   Click image for larger version
Old December 17th, 2010, 10:40 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
I have a dingbat question - do you have to pull the whole heater box to replace the core? Or can you drain the fluid, pull the heater hoses and then unscrew the core?
Am I totally off here?
-Ren Ching
Old December 17th, 2010, 05:10 PM
At least on my RHD 110 you had to pull the box to get to the rivets on the back side. No way to open it up in place. It's not hard to remove the box though.
Old December 17th, 2010, 05:33 PM
smob's Avatar
smob
Steve
Thanks Charles - I think that's the way it is with mine. That's a project for the spring, though.
-Ren Ching
heater
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
Avoid looking for help with your heater... wicks Defender Technical Discussions 2 February 3rd, 2004 09:46 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
