Heater - Defender Source
Old September 19th, 2007, 11:02 AM
Rubicon21
Andrew
1997 D90 ST (sold)
Heater
Starting to cool down with Fall around the corner and used the heater for the first time last night without much success. Anyone have an idea of how to get more air volume past the heater coil to produce more warm air? I had heard of modifing the heater flap at the vent, not sure if this will work? Any suggestions would be great.
Old September 19th, 2007, 11:23 AM
themaxx's Avatar
themaxx
Ade
94 ST
Not sure if you did a search...but there is a ton of info related this this.
Start with this: http://www.defendersource.com/forum/...16&postcount=2
http://www.defendersource.com/forum/...highlight=heat
Old September 19th, 2007, 11:28 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
You live in San Diego don't you?
Old September 19th, 2007, 11:32 AM
themaxx's Avatar
themaxx
Ade
94 ST
Hehe, when it hits below 70, they put sweaters on.
Old September 19th, 2007, 11:49 AM
Rubicon21
Andrew
1997 D90 ST (sold)
Will try the sweater first...funny... or putting the windows back on.
Thanks will try pushing the flap out of the way to increase air flow. The heater fan is pretty weak, maybe a replacement in order.
Old September 19th, 2007, 11:58 AM
themaxx's Avatar
themaxx
Ade
94 ST
Replacing it, might not help, they aren't that strong of a blower to begin with.
By the way, what year, color and type is your truck?
Old September 19th, 2007, 07:34 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
also make sure you go to the engine compartment and push on the lever coming out of the heater box, my cable is old and very hard to move, the lever doesn't fully get to hot position unless I push it there by hand. Only a little difference in position makes it either hot air or cold air..
~Steve
Old September 19th, 2007, 08:06 PM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
I have the same issue as Steve. I adjust the heater lever in the engine compartmeing. It makes a big difference for me.
Flagg
Old September 20th, 2007, 06:48 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
~Steve
my cables are broke, i zip tie the levers off in the summer and on in the winter and as Steve says it make a hell of a difference, exspesially with the lower lever which opens the flap fully on the bulkhead
3rd low and BOOT IT
heater
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
Heater hookup TDI Guy Defender Technical Discussions 27 April 19th, 2005 03:16 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
