Heat shield? and where does it go - Defender Source
Old December 11th, 2012, 11:46 AM
CDeWan
Clay DeWan
5.3L beastie
O.K. ran across the following heat shield in my box of NAS 90 parts and was wondering if it looks familar to anyone and where the hell it goes . Help.
Old December 11th, 2012, 11:47 AM
Under the RH rear side of the V8 manifold. Protects the starter. Yours is slightly kinked.
Old December 11th, 2012, 12:17 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Are there stock heat shields in the NAS 90 and 110? I don't think either of my trucks have any. Part numbers anyone?
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old December 11th, 2012, 12:31 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Ya there are a few. I know there is one over the clutch slave cylinder and one over the driver's side engine mount. And then of course the one already talked about protecting the starter. Probably a few more that I haven't found yet.
Old December 11th, 2012, 12:57 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
There is also one over the e-brake cable at the back of the t-case and another on the gas tank. Mine also had one over the cat on the RH side under the floor panel
Old December 11th, 2012, 02:27 PM
Reese_D90's Avatar
Reese_D90
Reese
These are the 2 that I need to add to mine.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old December 11th, 2012, 02:32 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
The one for over the RH cat is a pretty easy piece to make with some aluminum sheet and a work bench edge. The shield at the back of the t-case is a little more complicated because in theory it should be curved.
One other shield I remembered is a small one on the VSS
Old December 11th, 2012, 03:20 PM
Reese_D90's Avatar
Reese_D90
Reese
part #NRC 9724
This looks like its for the V8. You need 2, one to go on each side of the y-pipe. Anyone used these? Its bolts right to the pipe with a bracket. Looks like it would help the heat in the floor pan.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
