Heat Sheild - Defender Source
Old October 2nd, 2005, 12:46 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Heat Sheild
Does anyone know where I can find heat sheild material. The heat sheild above the right side cat is fubared & no one seems to be able to find it in their books?!{RN RDS TLR ECT}
Old October 2nd, 2005, 09:43 AM
COSteve
Steven Reed
93 Defender 110 - #107
Peter, Are you referring to the "fabric" type or the foil covered "panel" stuff that is around the starter, etc?
If the fabric, I ran into the same issue. The Dealer eventually found it on their books, refered to as a "grass shield" but it was unavailable.
My 110 had a fabric material protecting the Transmission Oil Cooler Lines that run past the Drivers Side Cat. It was soaked in oil and was actually hiding the fact one of the lines had rubbed through by being against the cat ..... but that is another story. (I actually think my lines running from the oil cooler to the back of the R380 Transmission are installed "upside down"...)
I fabricated a new shield by purchaseing a "Taylor Heat Blankets Heat Barrier, Heat Blanket, 14 in. x 6 in., Universal, Each 19.99 - part # TAY-2544 from Summit Racing. I folded it over the pipes and then sewed the edges together with Kelvar Thread that I purchased from a locall hobby shop.
I have not found the aluminumized panel stuff….
Old October 2nd, 2005, 10:32 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I need the panel stuff. I might just make one from a couple of sheets of Alum with something in between? Any thoughts?
Old October 2nd, 2005, 12:25 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Thumbs up
You can probably find what you need to repair your heat shield at www.heatshieldproducts.com
Look at the Inferno Shield in the automotive section. Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old October 2nd, 2005, 12:49 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Rob, Thanks! Send me a bill!!
Old October 2nd, 2005, 10:14 PM
Roadsiderob
Robert Dassler
1994 D90
Peter,
I am using some of their Reflecta-sleeve on the heater hoses and oil cooler hoses on a customers D110 that I have in the shop. Let me know how your heat shields turn out...maybe post some pics if you can. It looks like this stuff would work really good to remake damaged factory heat shields.
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old July 4th, 2007, 01:02 PM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
Heat Shield again
Long drives cause very hot floorboards, seat boxes and the tuffy making long pants and shirt sleeves a necessity! I have no carpets and want to keep it that way.
Does any one have any experience and success in using heat shielding on the firewall and underbody?
I'm considering the aluminised 'blanket' shield used in race cars but don't want to pepper the sheet metal with (more) screw holes. There are self adhesive versions available up to 400degrees, but I dont want it to fail and wrap around a propshaft.
Maybe there is a another, better solution?
Owen
Old July 4th, 2007, 01:26 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Mine has heat shielding all over the place around the cats, looks like the previous owner had it installed as it doesn't look like factory work. Some type of solid panel material on brackets, holds the shielding about an inch and a half away from the cats. Not bad work, but not stock for sure. I've never experienced the hot floorboard problems at all, they get warm to the touch, but nothing I even pay attention to.
Some versions you clamp to the body of the cats themselves, or the exhaust pipes, so no need to start drilling holes anywhere like was done on mine.
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 4th, 2007, 03:38 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Owen
I had the normal heat issues with my Defender that everyone else has. I went to my local hardware store and ordered a 100sq ft. roll of Peel and Seel or Peel and Stick, cant remember the exact name but it is essentially the same stuff as Dynomat with aluminium on one side. It ran me about $89 for the roll. I did my firewall, floor, seat boxes, doors, hood and ceiling headliner. In the engine compartment I used sort of fibreglass blanket and attached it to the firewall. I still have a few left of the blankets. Not only did all this help a ton with heat but also made a big difference in keeping the noise level down. Some naysayers told me the peel and stick would smell like tar or asphalt when it gets hot but 4 years later and many trips to the desert on 100+ degree days and it is holding up well and no smell. For $89 I did my entire truck with plenty to spare.
Old July 6th, 2007, 08:14 AM
owen's Avatar
owen
Owen Jones
Great, that sounds just like the way I need to go. Thanks for the advice!
Would you be willing to part with a couple of the blankets?
Owen
Old July 6th, 2007, 09:53 AM
I have a gallon of Second Skin Firewall arraving in about 2 weeks (brand new enhanced formula just released). I'm going to be brush painting it on both sides of the firewall, under the transmission tunnel and seat boxes, under the bonnet, and then remainder will be used on the roof interior. It is a liquid thermal insulation AND sound deadener. I'll report on the project and how effective it is after I'm done. If it works well, then I'll be herculining on top of it on the inside.
Old July 6th, 2007, 12:13 PM
Hans's Avatar
Hans
Hans Haase
Another suggestion to toss out there. If you have the ability to do it, also try to block the heat from getting at the starter as well. Really does help their lifespan.
My oil line fix
Old July 6th, 2007, 12:21 PM
Shake
Bob Hanson AKA Two-Socks
Red 94 D-90 #428
Hell...I thought that was the factory auxiliary heater on my truck cause the real heater isn't worth a poop. Save the heat shield stuff...I like it hot.
Old July 7th, 2007, 12:07 AM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I have Dynamat Extreme and Extremeliner on my footwells, and Dynamat Extreme under the seats and cubby box. I really didn't notice any improvement. On long drives in warm weather, it still gets really hot inside. I think my next attempt will be along the lines of Hans truck with the heat shields under the truck. I'm hoping the main heat source is the exhaust which will minimize the amount of shielding required.
Old July 7th, 2007, 12:11 AM
owen's Avatar
owen
Owen Jones
Yep thats what I'm wanting to do. Comfort and leg burns asside it cant be good to cook the computer and the battery!
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
Heat temps very low 1of40 Defender Technical Discussions 9 February 15th, 2006 04:39 PM
Heat insulation blankets kellymoe For Sale - Parts 1 July 13th, 2005 04:54 PM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
