Heat gauge moving as I turn the key - Defender Source
Old September 23rd, 2017, 07:39 AM
TheoH
Theo
94' 127 Defender
Hey Guys
I have a 3.5 V8 110, as soon as I turn the ignition on the heat guage goes from cold straight to hot. Where do I start looking. I know there is a new sensor in but think its a brit part. What else can I look at? to solve this problem?
Old September 23rd, 2017, 07:57 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by TheoH View Post
Hey Guys I have a 3.5 V8 110, as soon as I turn the ignition on the heat guage goes from cold straight to hot. Where do I start looking. I know there is a new sensor in but think its a brit part. What else can I look at? to solve this problem? Thanks
Sounds like you should check all ground connections, specifically engine to bulkhead. Also make sure the gauge is grounded. Many times the gauges are all sharing a single ground behind the dash. Double check.
Old September 23rd, 2017, 09:50 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
It's called a temperature or temp gauge.
In order for it to peg the high temp range the wire to the sender would have to be grounded.
Welcome from ZA.
RDavisinVA
Old September 23rd, 2017, 10:10 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Hey Guys
Hello Theo, as you are in Africa you sure that's not the outside temperature gauge lol, but as said above you have a wire shorting on sometime or the new sender is nackered. Also use No tread tape to seal the sender. Good luck in your quest.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 23rd, 2017, 10:15 AM
The Dro
Dro
1988 Ninety
Check your negative connections
Old September 23rd, 2017, 12:36 PM
Chris B
72 + D1 drivetrain =?
The voltage is going straight through as if the wire connection from the gauge is fixed to the block.
Replace defective sensor
Old September 23rd, 2017, 01:51 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Good advice.
The sender wire could have come loose and grounded.
RDavisinVA
Old September 24th, 2017, 03:01 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
with a VDO sensor & gauge.
vin
VDO Fuel Gauge moving around when driving????? bradfordish Defender Technical Discussions 30 January 4th, 2016 12:16 PM
Help! Cant get the key to turn over hotroddef90 Defender Technical Discussions 10 October 27th, 2012 04:51 PM
Ignition key won't turn! cgalpin Defender Technical Discussions 11 March 27th, 2010 06:42 PM
Dumb ignition/door key question, did search first Neo Defender Technical Discussions 15 May 30th, 2005 07:10 PM
