heat - Defender Source
Old January 7th, 2009, 05:44 PM
cosmickites
mike
1995, defender 90
heat
strange, when I put the heat on full blast warm air (not hot) comes from the drivers side, and cool air blows on the passenger side.
any thoughts a) why its not hot air, and b) why cold on one side of the truck?
1995 defender 90 NAS
Old January 7th, 2009, 06:02 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I had a similar problem and a new water pump fixed the problem real well. I'm still not sure why I had a bit of a temp difference from side to side.
And hay
And I love you too
Old January 7th, 2009, 06:33 PM
cosmickites
mike
1995, defender 90
interesting. however, my temp guage reads perfectly well. you still think it could be the water pump?
also, how hard was it to install the water pump?
expensive?
Old January 7th, 2009, 07:31 PM
Check your thermostat too...
Old January 7th, 2009, 08:29 PM
huck1974's Avatar
huck1974
shane cates
94 d90
expensive?
Mine didn't get real hot either. Not a hard job. Was around $150 if I can remember right. Thermostat is like two bits at the auto parts store. All of the above took part of a Saturday morning and my soft top is warm enough to be bearable even when it is zero outstide.
And hay
And I love you too
Old January 11th, 2009, 09:36 AM
cosmickites
mike
1995, defender 90
well, it was the simplest fix ever and only cost me 2 minutes of time. apparently when you slide the heat lever up and down it moves a cable under the hood which controls the opening and closing of some sort of valve. well, with the lever in the full high heat position it was not opening the valve all the way. i manually pushed it all the way open and adjusted the cable accordingly. Now i think i can have the top off in the middle of winter, it was SOOO hot in the truck. totally stoked. thanks to all that took the time to offer feedback.
Old January 11th, 2009, 07:27 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Good deal man!
And hay
And I love you too
Old January 11th, 2009, 08:02 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
I'm hoping that this is my problem, too.. Will be under the hood tomorrow.
-Ren Ching
Old January 11th, 2009, 09:00 PM
isleofman's Avatar
isleofman
Lee Davis
'95 D90 "BeastLee"
glad i read the thread. i'm ducking under the hood too tomorrow to check things out. always freezing my butt off and tired of it. time to crank that heating up a little. thanks.
Old January 12th, 2009, 10:28 AM
smob's Avatar
smob
Steve
Thank you, Jesus, as I found that the cable was easily pulling the cold on, but not pushing the hot.. The switch for the heater vent is now jammed all the way open, thanks to a little wrench pulling. I'll work out the slack issues once it gets a little warmer outside.. Thanks to all for the advice.
-Ren Ching
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
Heat Sheild Bowtracer Defender Technical Discussions 14 July 7th, 2007 12:11 AM
Heat insulation blankets kellymoe For Sale - Parts 1 July 13th, 2005 04:54 PM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
