Heat - Page 3 - Defender Source
Old June 4th, 2013, 11:31 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Haha!! I was wrong about one controlling the fan that is done by the electrical switch. The top lever controls the lever nearest to the fan, the other on the side closes the entire box. I would make sure both are closed.
ID:	73807   Click image for larger version
Old June 5th, 2013, 07:34 PM
ssi19's Avatar
ssi19
scott
1995/D90
I played with it a bit. I still can't figure out what closes, and what openins the vents (when forcing the levers manually on the heater box).
Old June 5th, 2013, 07:48 PM
The one on the top controls a flap that forced air through the heater matrix or bypass the matrix. The one on the side closes the entire box from the outside stopping all air flow.
Old June 5th, 2013, 08:09 PM
ssi19's Avatar
ssi19
scott
1995/D90
Thanks. Facing the heater box (facing rear of truck ) if I want to stop all air from getting in the cabin (especially hot air) which direction do I force all the levers?
Old June 5th, 2013, 09:05 PM
On the top heater control. Cable pushed out (left on LHD) is hot, pulled in is cold.
On the side air flow, pushed out (down) is open, pulled in is closed.
Disconnect the cables and make sure they are being forced tight. There is a clip on the cable sheath that you can pop on and off to adjust this tension.
Old June 5th, 2013, 09:08 PM
ssi19's Avatar
ssi19
scott
1995/D90
Awesome. Thanks a bunch
Old June 10th, 2013, 09:16 PM
ssi19's Avatar
ssi19
scott
1995/D90
I've engaged in an all out assault on the heat and smell. 1) dynamat inside ST doors 2) near driver pedals/footwell 3) inside driver seatbox (also found a sizable cable hole in there missing a gasket/cover) 4) inside e brake boot cover 5) and manually closed all vents using levers ON the heater box. Long drive this weekend will report back. Yes I know defenders are supposed to smell. Purists can email directly with complaints!
Old June 11th, 2013, 08:53 AM
What are people using under the hood?
Old June 11th, 2013, 10:51 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Dynapad is good stuff, more sound absorption then regular dynamat. And looks better, just a black matte finish.
Old June 11th, 2013, 07:52 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Dynapad is a half inch thick and is really intended for use under carpet, not under the hood where it can get wet. Dynaliner will hold water as well, not at all what you want to use under the hood on a defender. Or anywhere on a defender for that matter. Im sure it would work great in a civic.
DEI makes some nice stuff, aluminum skin over fiberglass, adhesive backing, all less than 1/4 inch thick. Withstands up to 1700 degrees, the adhesive holds to 450.
Old June 11th, 2013, 08:33 PM
Lemonhead
TB
1997 D90 SW
I used this.
www.b-quiet.com/hliner.html
Easy to cut and apply - I did other various sound deadening throughout plus new thicker carpet and front rubber mats.
Quieter for sure but not super quiet.
The Hliner appears to keep the hood cooler as well.
Old May 9th, 2014, 09:31 AM
RedRoverKatyTx's Avatar
RedRoverKatyTx
Scott Frost
1987 Defender 110 RHD 2.5 deisel
I used Hushmat under the bonnet, inside the cab and took the door panels off and lined them. It's not only great sound barrier but these type of mats really "thicken" the wall of the sheet metal. If you tap on my bonnet, it sounds / feels like solid steel. Same for my door panels.
ID:	94583   Click image for larger version
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
Heat Sheild Bowtracer Defender Technical Discussions 14 July 7th, 2007 12:11 AM
Heat insulation blankets kellymoe For Sale - Parts 1 July 13th, 2005 04:54 PM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
