Headrest removal - Defender Source
Old January 20th, 2008, 07:28 PM
azD90's Avatar
azD90
Kevin Houseal
1994/D90
Headrest removal
Installing some custom made neoprene seat covers and can not figure out how to get the headrest off. I've had cars that have a hidden button under the upholstry but can't find it on the 90. I've checked the archives only to see that a group of you were refitting trim kits a couple of years ago. Anyone? Thx.
Old January 20th, 2008, 09:56 PM
I am not sure that you can remove them... I have sheepskin on the SW and LR waterproof on the ST, and both have velcro openings to allow you to pull them over the head rest. I have never been able to remove them.
Old January 20th, 2008, 09:57 PM
they just pull up- no buttons like on a bmw.
Old January 20th, 2008, 10:33 PM
Mendicant
Yeah, just pull - hard.
Old January 21st, 2008, 06:28 PM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
Actually, ... you have to pull really, really, really hard, and as was the case with mine, ... the post on the headrest was fused to the seat back with surface rust (that cleaned off with steel wool once the two came apart!)
FYI.
DJ
Old January 21st, 2008, 06:42 PM
azD90's Avatar
azD90
Kevin Houseal
1994/D90
Well, I got 'em! I found a UK site with a bunch of blokes asking the same question. What they described worked but it may be overkill. You undo the clip along the bottom back of the OEM trim. Peel the cover up to expose the headrest bracket (a pain). The bracket is in a flat tube and has a one-way retaining clip acting as a catch. A flat screwdriver up in there will pull the clip in and out of the way. Then because of the surface rust I gave it a whack with a 3lb hammer. --The reason I said it's overkill is that if it isn't fused with rust you could probably just wallop on it till the clip breaks.
Old March 8th, 2013, 07:04 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Had same issue and major PITA. Ended up using a screwdriver to dislodge and needle nose pliers to pull out. Very excited to throw the useless clip away when done.
"These are the best traveled nuts on d-90 . . ." ABrooks
Old March 8th, 2013, 09:04 PM
PB Blaster and faith, I thought I was going to pull the seat box out.
Old March 8th, 2013, 09:32 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Just happy to have the Melvill and Moon seat covers on at last.
Old March 8th, 2013, 11:46 PM
Dude, way to revive a 5-year old thread. The least you could do is throw some pics our way of the new M&M covers! Jeez.
Old March 9th, 2013, 07:14 AM
Stormer's Avatar
Stormer
JP
2008 RRSC
Removing the stupid pointless clips in the headrest base was such a memorable crap experience, I wanted to commemorate it in some way.
I would post pictures but when I finished it was completely dark and snowing like crazy. Maybe today.
Old March 9th, 2013, 12:35 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Obligatory crappy IPhone photos
ID:	67763   Click image for larger version
Old August 2nd, 2014, 02:05 PM
ssbartley1's Avatar
ssbartley1
Steve Bartley
1997 SW #160
Holy Hell- you guys weren't joking about having to really pull on the headrests. Got them off, and my new seat covers on.
Steve B-
Otterberg, Germany
"Walk tall, kick ass, learn to speak Arabic, love music and never forget you come from a long line of truth seekers, lovers and warriors."
- Hunter S. Thompson
Old August 2nd, 2014, 02:53 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Do you think they could have made the head rests any taller ? The things look so dorky.
Old July 17th, 2016, 09:08 PM
Good tip - I could not get them out no matter how much force I applied in trying to lift them up. Gave up after 15 minutes or so of that monkey bidness. So, off to the innerwebs. After reading this, I removed the trim cover and carefully applied some PB Blaster (didn't want to get that sweet aroma all over the seat). 5 mins later, they pulled right out. Didn't even need a screwdriver.
Old July 18th, 2016, 08:19 PM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
I want some M&M seat covers. I'm not looking forward to removing my headrests either. I'm sure they're fused with rust too. I'm tempted to buy the parts to turn them into Puma seats with the adjustable headrests.
Old July 19th, 2016, 12:57 AM
3ft prybar. They come off.
Old July 19th, 2016, 01:56 PM
just pull until you think youll break it
Old July 19th, 2016, 08:30 PM
Jedelmann's Avatar
Jedelmann
John Edelmann
1994 Defender #1194
Headrest Removal Tips. Here are step-by-step instructions on how to do it:
Step 1. Try to pull out the headrest.
Step 2. If that doesn't work repeat Step 1 but pull harder.
Step 3. If that doesn't work, peel up the OEM seat cover up to expose the headrest bracket on the back on the seat. The headrest bracket is in a flat tube and has a one-way retaining clip that acts as a catch.
Step 4. Use a a punch and hammer to knock the clip out of the way.
Step 5. Pull out the headrest.
Step 6. If that doesn't work, use a hammer to knock the headrest loose which may have surface rust that's preventing removal.
Step 7. Once removed, fold back down the OEM seat cover and re-secure.
84 110 Dormobile
94 D90 ST
14 RRS
Old July 15th, 2017, 11:27 PM
wbroadway
Will Broadway
1989 Defender 90
Early 89 TD Headrest
Sorry to bring this back from the dead but had a hard time getting my 89 D90 headrest off. Simple now I know how.
1. Pull off Seat cover separate snap track at the base.
2. Left hand side there is a clip low on the headrest. Push in a pop it off.
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Easy heater removal ??? artm Defender Technical Discussions 1 October 10th, 2003 08:27 AM
