Headliner materials? - Defender Source
Old February 10th, 2016, 09:56 PM
Kurt's Avatar
Kurt
Kurt
1967 SWB
Hello - finally getting to some upgrades / improvements for one of my trucks....
I am looking to replace the headlining in my D130 - the finished face has fallen down and was half cut off by the PO so doesn't look too good to say the least...
Options:
- buy a new factory style headliner from UK (found one but shipping is $$)
- Lasalle trim headliner also from UK (even more $$$$$$)
- reline the existing backing at a local shop with either a brushed felt headliner or smooth fabric (reasonable $)
Durability / washability -
- Lasalle headliner is likely best as it's plastic
- relined likely least durable (concerned it will peel away from the backing in a couple years?)
- new OEM style?
Other consideration is the materials used for the factory headliners - in one of my trucks the headliner is actually a thin smooth vinyl which is very easy to wipe but not sure what current production would be finished like.... If a new one is going to be the same material as I would get from a local upholstery shop I won't bother getting it from the UK.
What is the headlining in your truck made of?
Suggestions on other ways to finish?
Old February 10th, 2016, 10:10 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
On my old pickup truck the headliner was bad so I seperated the foam from the fiberglass backing, and spent $20 on new headliner material(foam with a cloth layer over it) from Jo-Ann Fabrics and $10 on a spray adhesive and it came out looking great. Spent a couple hours doing the job.
Old February 10th, 2016, 10:14 PM
i have a lasalle. why dont you consider taking your old headliner to a shop to use as a mold for a fiberglass replica.
lasalle's are fiberglass, not plastic
Mark Kellgren
KM4BOR
Old February 10th, 2016, 10:30 PM
The resto shops in the UK were pimping recovering with alcantara aka ultra suede
I used the sister product, Ultra leather for the cushions in my boat and everything (blood, fish guts, vomit etc) wiped right off of it. Amazing material.
Old February 11th, 2016, 06:28 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Any good trim shop will be able to take what you have and put a new cover on the backing. With that said it will only be as good as the backing. If you have had a lot of leaks in the past that material might not be the best. I just did the 110 by a local shop and it turned out very nice. My backer board wasn't in too bad of condition. You do have to remove the old material first which may be a pain if it is still on pretty good. I paid about $750.00 to have everything done headliner and window trim pieces as well the other trims.
Land Rover 110
Old February 11th, 2016, 10:10 AM
MisterSHO
David K
87 110, 95 RRC
What goes on in that boat?
Old February 11th, 2016, 10:29 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Clearly you're not a boater
Old February 11th, 2016, 11:24 AM
Offshore sport fishing. Usually 60+- or so miles offshore for pelagic's (tuna, marlin, sharks etc).
Got caught that far off NJ once in a storm and some of the guys lost their stomachs.
o-ring materials for gasoline and brake fluid ? JFD Defender Technical Discussions 1 April 23rd, 2013 03:13 PM
Soft Top (hood) materials Chris Velardi Defender Technical Discussions 2 July 2nd, 2011 04:23 PM
Sound Deadening Materials punter Defender Technical Discussions 7 November 20th, 2010 10:22 AM
Constantly confused by bolt materials fenwaystan Defender Technical Discussions 7 August 24th, 2009 12:10 PM
headliner rover4x4 Defender Technical Discussions 15 February 23rd, 2004 06:49 PM
