headliner - Defender Source
Old February 17th, 2004, 05:01 PM
headliner
where do yall thin i could get a new headliner for my SW? George said he didnt have em.
Old February 17th, 2004, 05:18 PM
or if any of yall have had issues with a saggy headliner how did you address them?
Old February 17th, 2004, 05:44 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Mine does, infact both are sagging. If George doesn't have them then you might have to try Rovers North or British Pacific and of course, your local dealer.
DJ
Old February 17th, 2004, 05:58 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Phillip, try thatched roof garage. They import stuff from lasalle trim. They should be able to get what you want. I think their headliners are made different than genuine, and do not sag or come apart.
Old February 17th, 2004, 11:07 PM
mattdh's Avatar
mattdh
Matt Hurst
has any one here order any of the lasalle products?hows the quality?can you take pics
Old February 17th, 2004, 11:47 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Find a local upholsterer. When I needed a new headliner for my RR i took it to the most run down upholstery shop in town. They did it for $80 and looked better than new. Shop around I bet you can find a great deal. Many upholsterers are immagrents sp?who take take grat pride in there work. I also had both front seats of my disco reupholstered for $95 by the same guy. Other shops quoted me $400 for the same job. It pays to shop around.
Old February 18th, 2004, 10:00 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You have two real options Phil. I would not bother with price checking a genuine headliner. They are ridiculous and will only sag in another 3-4 years time or less. I think RN quoted me $500-700 just for the rear portion of the SW 90.
Kevin is right on. You can take it to an upholstry shop. Only concern I would have there, is that depending on their methods, your still going to have to deal with the headliner down the road. Remember, the genuine piece is little more than cardboard with foam and fabric all glued together.
I ordered a LaSalle piece from David at Thatched Roof for mine. It should show up at the shop sometime today. I'll take pics next time I see the truck for everyone, maybe this weekend if I can get the time to install it.
Essentially, it's fiberglass. So no sag, and longer lasting. I think the cost for the entire headliner was $320.
So, I would say depending on how long you plan to keep that thing, you can squeeze by with getting it upholstered now, or replace it with somethign that will last indefinitely.
Old February 18th, 2004, 11:16 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
My headliner sags over the Alpine windows and the fabric was seperating from the felt(?) liner. I took it an upholstery shop and they reglued the fabric, and they used Velcro glued to the area over the window and the headliner to stop the sag.
The fabric looks great but the Velcro doesnt hold the headliner up.
I was thinking about using using some sort of metal clip epoxyed to the metal roof that could be bent to hold the headliner. Maybe sort of a J shape.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old February 18th, 2004, 11:39 AM
cool i have looked at the Lasalle stuff I think that might be what i get, I may also take it to a uphoslstry shop and see what they can do. I will be looking for your photos.
Old February 18th, 2004, 02:27 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I used metal display rack pins from the hardware store to hold up my alpine window sag. Just cut them to fit. (three prongs on one end and a long bar that holds display merchandise on a rack.) I used 1/2 screws with big washers to lift the sagging fabric in other areas. I don't even think about it now, but someday when I want to do the soundproofing job, I'll go with a LaSalle.
Doug
Old February 18th, 2004, 02:33 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
hey Doug, it's a bit off the topic, but you mentioned using Teflon to lubricate the Mantec slider? Where did you resource the Teflon spray? Thanks
DJ
Old February 18th, 2004, 02:49 PM
any bike shop should have it. TRI FLOW in the aerosol can or in a drip container choose your weapon. I think a teflon based greese would be perfect.
Old February 18th, 2004, 03:20 PM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Take your roof off and have it Rhinolined.
I did that on my CrewCab but now I think I want something up there that absorbs sound. Rhinolining doesn't (it actually reflects it quite well). But, it does insulate pretty well keeping the hot and cold out and the heat and cold in (respectively).
M
Michael Slade
www.tawayama.com
Old February 18th, 2004, 03:45 PM
Doug's Avatar
Doug
Doug Walker
TriFlow. Bike shop, exactly, Phillip.
Old February 18th, 2004, 03:48 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Perfect! Thanks guys.
DJ
Old February 23rd, 2004, 06:49 PM
WCURoverD90's Avatar
WCURoverD90
Jason Habbal
1997 Defender 90 #1104
Little upholstry shops can do wonders...my friends dad owns one back home and i accidently ripped about 3 inches of the weather stripping off my soft top and he sewed it back up like brand new...unless you really look hard you cant even tell that it was ripped...i would say check out those little shops and see what they can do
Jason Habbal
"tell them to phucough"
Land Rover-The Best 4x4xFar
NAS 110 Headliner Material 3rovers Defender Technical Discussions 4 August 27th, 2008 12:04 PM
How thick is a LaSalle headliner? Need for roll bar install peachyracer Defender Technical Discussions 24 June 11th, 2008 03:21 PM
FS: Headliner Vinyl dzientek For Sale - Parts 0 January 29th, 2007 11:27 AM
How to ship lasalle headliner and SW trim panels? Chris Cox Defender Technical Discussions 4 March 23rd, 2005 08:07 AM
Headliner in 95 SW dbwitt Defender Technical Discussions 4 October 11th, 2004 03:25 PM
