Headlights - switch problem? - Defender Source
Old December 13th, 2005, 09:10 AM
mgrgpg
Mark
1989 D110
This started happening a few days ago - when I switch the headlights on, my passenger side light is very dim, driver side normal brightness - but my high beam indicator lamp lights up faintly even though the high beams are not on. When I switch the high beams on and off then the light goes to full brightness and the blue instrument light goes completely off. Is it the bulb, wiring or switch? FYI - I changed out the headlights a few weeks ago to Hella Vision Plus.
Old December 13th, 2005, 09:30 AM
I would double check the connections and look for a possible short...
Old December 13th, 2005, 01:37 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Use the search.
Old December 14th, 2005, 03:42 PM
mgrgpg
Mark
1989 D110
OK- Point taken to run the search
Did a search - read through the threads came up with the following:
1. Could be the switch
2. Check for shorts in the wiring
3. Check the fuses - ruled this out since the lights all work after I switch the high beams on and off
4. Check all connections
So - unless I missed a post of the same problem, will start with the connections, and continue from there.
Mark
ht, lights, switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
Help - My 90's headlights don't work solihul Defender Technical Discussions 5 May 20th, 2005 01:27 AM
