Headlights suddenly stopped working - Defender Source
Old January 25th, 2015, 02:05 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I'm driving down the freeway, and the headlights, marker lights and dash board lights just turned off.
The marker lights still work with the switch in the middle position (marker lights only on), but as soon as I move the switch to the 3rd position, everything including the dash lights go out. BTW, the high beams will flash with the switch in the middle position.
What could it be? I've checked all fuses, and the fact that the high beams still work leads me to believe it's not the headlights.
What should I look for? What should I check/test? Truck is an'86 D110, V8.
Thank you.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old January 25th, 2015, 02:39 AM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
Sounds like your switch is bad. Mine has gone out and I had to remove the bottom cover, under the steering column, and make a jumper wire where the light switch plugs in until replacing the switch.
Old January 25th, 2015, 03:02 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
X2. Same remedy. Mine went out on a twisty! Thank God for the 6 forward Hellas! ;-) New switch, wired right, never happened since.
Old January 25th, 2015, 08:00 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Man, just had this problem too. If you installed upgraded headlights (more wattage), then this is definitely the problem. Even if you didn't, from I've learned, the switch will go out eventually because full power is being routed through the switch (no relays).
Take out the main light switch, replace it, and put relays in for the headlights like the ARB M002 relay and wiring loom setup (plug and play).
Old January 25th, 2015, 09:17 AM
It could be the switch itself, to check just pull the switch...and unplug it. You'll see the wires on the back of the truck-side plug. Just jumper the brown wire (12v) to the blue wire, and then the red. Those are the headlights and marker lights. See if the headlights come on when you jumper it. If they do, switch is bad.
Other possibility is that it could be the dip-dim switch.
Lastly - and this is what it was for me when I had this issue back in October in the 1988 130. Some trucks in the 80s actually had a "dip-dim relay" installed. Some sort of archaic regulation in the UK, which was later done away with. Most people just bypass it, since the relay serves literally no purpose. My relay went out, and took me a bit to track down the issue so it's worth checking. It lives behind your dash binnacle, details here:
http://simkin.org/wordpress/?p=248
Old January 25th, 2015, 10:22 AM
That switch is the weakest link in the Defenders electrical system. Oh wait, the electrical system is the weakest link in the electrical system. After you swap it out get a relay controlled harness or LED headlights to remove the strain on it. You will have brighter lights and the switch should last much longer with milliamps running thru it instead of a full electrical load.
Old January 25th, 2015, 12:21 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Dave,
Are there pre-made harnesses available for this application, or are you referring to the typical 12V Bosch relay harness that I have to wire in?
Thanks - Samer
------ Follow up post added January 25th, 2015 09:25 AM ------
Jason,
Thank you for the tip on testing the switch and the link to the article. I will test the switch today, and report back.
Samer
Thank you - Samer
2003 Discovery II
Old January 25th, 2015, 12:33 PM
Samer,
ARB is one of many manufacturers who make a harness that will work or you can make your own using QUALITY relays.
Old January 25th, 2015, 12:37 PM
Originally Posted by samer0214 View Post
Dave,
Thanks - Samer
Jason,
Samer
Samer:
DEFINITELY do some testing before you start throwing parts at it...I made that mistake and was convinced it was the dip-dim switch (which, based on my testing it was - I just was unaware of this "dip-dim relay" potentially being a factor). So I ended up with a brand new dip-dim that I didn't need. My situation was a little different like I said, but worth a time investment on your end.
Also, if you do have interest in an ARB harness I *may* have one to part with. Regardless, it is plug-and-play and takes the "switch" out of the equation and adds relays for the headlights.
Old January 25th, 2015, 05:43 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
You need a new headlight switch and this ....
http://www.ebay.com/itm/H4-Relay-Har...0c2cc8&vxp=mtr
Be sure to get one with ceramic head lamp connectors because plastic units melt
Old January 25th, 2015, 07:13 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Wow, That harness is cheap!!!
Old January 25th, 2015, 10:12 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Jason: Definitely interested in the ARB harness. Please let me know.
Thank you - Samer
2003 Discovery II
Old February 7th, 2015, 09:05 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Posting a follow up to my problem. Replaced the headlight switch with a new one, and everything is working again. About to upgrade the wiring to the ARB harness I bought from Jason.
Thank you - Samer
2003 Discovery II
Old February 7th, 2015, 09:15 AM
rankar's Avatar
rankar
You'll notice a significant improvement once you have the new harness in place. Lights are brighter, high beams flick on quicker, and you might have an oncoming car flick their high beams at you thinking yours are on (yeah ok, not likely)
Old February 11th, 2015, 10:27 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
So, after successfully replacing the main light switch with a new one, and checking that everything was working, I upgraded the wiring harness to an ARB harness that I bought, and I now am faced with a new set of issues:
1) When I turn the lights on (with main switch), they come on in the high beam mode.
2) If I push the turn signal/high-low beam stalk forward to the high beam position, the lights go into low beam mode.
3) If I use the same stalk to flash the high beams, nothing happens (because they're already in the high beam position"!
Isn't the ARB harness supposed to work with the Defenders right out of the box, so to speak? I know I wired it correctly, it was child's play, straight forward!
Any clues as to what might be happening?
Thank you - Samer
2003 Discovery II
Old February 11th, 2015, 10:51 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
They were already plugged in. I didn't check or move them.
Thank you - Samer
2003 Discovery II
Old February 11th, 2015, 10:53 PM
From what I've read (in the ARB pdf), the relays need to be plugged into the harness in a particular order/spot. Could you have switched the high & low relays? It says something like "relay 2 and 3 switch the high and low beam respectively".
The other thing - though honestly I'm not sure why or if this would have any bearing - but did you look behind the dash binnacle to see if you have the "dip-dim relay" that I alluded to in post #5 above? Again, just curious if that is still in the circuit (in the event that it may be causing an issue...though I highly doubt it).
Old February 11th, 2015, 10:58 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Jason. I didn't touch the relays, I installed the harness as it came from you. I will have to check them tomorrow.
That'll be a PITA, since I installed them and 3 other relays in a nice covered enclosure in the engine bay!
N.B. I don't have the dip dim relay mentioned in your post earlier.
Thank you - Samer
2003 Discovery II
Old February 11th, 2015, 11:19 PM
May be worth "double checking"....it is brand new in the box (i.e. nothing was touched), but not to say that ARB couldn't make a mistake when things were plugged in/etc (assuming that if the relays were switched that could cause an issue - which I'm just hypothesizing about).
Old February 11th, 2015, 11:28 PM
Samer,
If you successfully tested all the switch functions before you installed the harness and you are now having issues the harness is jacked up. There is no way that it shouldn't work. You are supposed to be getting the signals to the relays from one of the original headlight plugs. If they are activating something else the harness (relay(s)) isn't correct. Call ARB and they will help you.
ht, lights, top
Front blinkers stopped working meow Defender Technical Discussions 8 September 16th, 2013 08:22 AM
Headlights stopped working JTull Defender Technical Discussions 17 November 29th, 2012 06:26 PM
AC stopped working. TxEddie1111 Defender Technical Discussions 5 September 23rd, 2010 03:27 PM
Indicators stopped working ... leastonce Defender Technical Discussions 1 November 2nd, 2009 10:25 AM
wipers stopped working MontanaD90 Defender Technical Discussions 1 February 25th, 2008 01:27 PM
