headlights out... where to look - Defender Source
Old November 12th, 2010, 03:07 PM
jijalicious
Jiman Khosravan
'94 D90
Unhappy headlights out... where to look
Afternoon,
Another day, another problem it seems... but it's ok.. soon all the bugs will be gone...i hope!
This problem just happened 2 days ago...
The headlight switch has 3 positions... !) OFF, 2) parking and 3) headlight+parking.
1) OFF works
2) Parking works
3) it becomes all OFF again
I opened the casing around the steering column, pulled the cable out from the switch and disconnected it.
I put a voltmeter to the switch and tested the switch and I get voltage across position 2 & 3, so the switch is good.
So I need to somehow go down the wiring. Anyone know where the next "junction" to troubleshoot is?
Or any ideas on where to look?
~Ji
Old November 12th, 2010, 03:14 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
I assume you have tried the fuse for the main & full beam as they are on a separate fuse from the side(parking) lights, or the headlamp relay.
I have seen the switch go short cct and blow the headlamp fuses.
have fun..
Gren
Old November 12th, 2010, 03:19 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Pull the switch out and look at the 3 copper connections inside. your 3rd copper hit point might be burned out. Its a common problem. Happen on mine 4 years ago. You can buy a new one or fix the connection.
Edit: oops! just read that you tested voltage across position 2 & 3 and it was good.
Old November 12th, 2010, 03:20 PM
Switch is hosed. Under the high load of the lights they go bad.
Only other possibilities are the fuse or having both go out at once (my LWB did this and I was like WTF for a good hour until I figured it out the "Ron good" way ie replace parts until it works again).
Ron
Old November 12th, 2010, 03:35 PM
dchapman
Daniel Chapman
1999 D1
Does the inside of your switch look like this?
Old November 12th, 2010, 03:55 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
My Series had this problem. It was the hi-low beam switch that went out. I am not sure this applies to the Defender class trucks.
Firemanshort
1980 Stage One 109
Sterling, VA
Old November 12th, 2010, 06:34 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I would buy a new switch after looking at the fuse first of course. Mine did the same thing and the switch looked good but had melted just enough to not make contact when the switch was moved to the 3rd position.
ht, lights
Low Beam Headlights Quit JimC Defender Technical Discussions 7 January 29th, 2006 07:54 PM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
My headlights are not working woldd90 Defender Technical Discussions 13 December 2nd, 2005 10:49 AM
Yaaaaaaaaaaaarg! Frigging headlights solihul Defender Technical Discussions 2 June 23rd, 2005 10:29 PM
Help - My 90's headlights don't work solihul Defender Technical Discussions 5 May 20th, 2005 01:27 AM
