Headlights not working on low beam.... - Defender Source
Old June 25th, 2009, 12:02 AM
KKilo23's Avatar
KKilo23
Kenny
When I turn the lights on everything works fine, dash tails etc... but the headlights do not. When I flash my highs they come on, and go off soon as I let go of the high beam stick.... any ideas? Thanks
Old June 25th, 2009, 12:12 AM
Bad switch. If it makes you feel any better I put in a new switch and now my brights don't work.
Old June 25th, 2009, 12:14 AM
KKilo23's Avatar
KKilo23
Kenny
Argh... Which switch should I replace....the brights/directional/horn or the light switch it self smaller on the steering column?
Old June 25th, 2009, 12:22 AM
Smaller one. If you look below on "Similar Threads" you will see a bunch of people who had the same issue.
If I were you I would spend some extra dough and buy:
http://www.expeditionexchange.com/ca...5&cat=0&page=1
and
http://www.expeditionexchange.com/ca...6&cat=0&page=1
Or this
http://www.expeditionexchange.com/ca...7&cat=0&page=1
Depending on if you have a 1993-95 or a 1997
Old June 25th, 2009, 07:21 PM
KKilo23's Avatar
KKilo23
Kenny
and
Or this
Great, I am going to try this! btw have a 97 SW...
btw, is the ARB wiring loom a pretty straight forward install? Thanks!
Old June 25th, 2009, 07:46 PM
Don't know. It is on my list. John or Ho at expedition exchange can tell you.
Old June 25th, 2009, 08:14 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Thats what aux lights are for.
Old June 26th, 2009, 12:18 AM
yep straignt forward except for locating a good constant pwr.
you can do
1) tap into the existing engine main fuse block (near the master cylinder for the brakes - pry carefully there are 2 clips if you use that as is (no cutting) )
2) run a dedicated Pwr from the battery to the engine comptment - which is what i am planning after doing #1
the plugs match up so its pretty straight forward - mount the relays to something you either have or can Fab up and hand from the fender using existing holes (i used 2 2" brackets bolted together to make an upside down T
95' D90 - daily driver..
ht, lights
Low Beam Headlights Quit JimC Defender Technical Discussions 7 January 29th, 2006 07:54 PM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
My headlights are not working woldd90 Defender Technical Discussions 13 December 2nd, 2005 10:49 AM
Yaaaaaaaaaaaarg! Frigging headlights solihul Defender Technical Discussions 2 June 23rd, 2005 10:29 PM
Help - My 90's headlights don't work solihul Defender Technical Discussions 5 May 20th, 2005 01:27 AM
