Headlights lost while driving - Defender Source
Old September 30th, 2011, 06:25 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
I'm driving down the road and all of a sudden my headlights and parking lights go out. I switch on the brights and they work but the main beams don't. Turn signals work, high beams work, brake lights and reverse lights work. Checked the fuses and nothing is blown. Does it sound like a relay, the light switch or wiring?
Old September 30th, 2011, 06:50 PM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
Light Switch is toasted to me. You should go extra relays when new switch is installed.
Cheers,
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old September 30th, 2011, 07:15 PM
USLandy's Avatar
USLandy
Andrew
defender 90
I had that happen to me, my problem was a old relay. Mine is located behind the dash, not sure about the NAS though
Old September 30th, 2011, 08:10 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Switch
Old October 1st, 2011, 04:45 AM
Defender90_218's Avatar
Defender90_218
Trenton Smith
1997 D90
Yep, one of the switch terminals if fried/loose/corroded. Had it happen twice.
Old October 1st, 2011, 09:00 AM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
My vote is switch. Had the exact same problem once.
Old October 1st, 2011, 10:05 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Me too
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old November 1st, 2011, 01:52 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
For future reference it was the switch. Installed a new one and everything works as it should. As a side note, all the dash lights are much brighter with the new switch, it must have been on way its out for a while because I had noticed that the dash lights looked really dim before.
Old November 1st, 2011, 01:56 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Agreed.
Hey Abe, are you back?
KAA
Old November 1st, 2011, 02:12 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
The switch usually goes bad because of the plastic pieces that hold the contacts in place inside the switch, to keep these from melting wire up the switch to use only as a signal to a relay here is a wring diagram I made up. (using higher wattage bulbs also exacerbates the problem.
Name:	Heavy Duty head light wiring diagram.jpg
Chris "V"
Old November 1st, 2011, 11:42 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
I was turning on the lights one night and the switch broke it's guts. But the brights worked fine, akward driving home with the new Hellas installed lol. Not too many happy people in opposing traffic.
Old November 1st, 2011, 11:58 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Similar thing happened to me. Past owner added aux hellas but routed them through the switch not directly to the battery. I was driving in the deepest pitch black woods with brights on when suddenly everything fails and goes black. Luckily low beams still worked. All that power going through the switch would over heat the switch enough to cause the contact to bend and loose contact. Parts of the plastics were melted. The switch is not made for this. Use relays!
ht, lights, vin
Low Beam Headlights Quit JimC Defender Technical Discussions 7 January 29th, 2006 07:54 PM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
Yaaaaaaaaaaaarg! Frigging headlights solihul Defender Technical Discussions 2 June 23rd, 2005 10:29 PM
LR Driving School in Canada OCD90 Misc. Chit-Chat 8 October 5th, 2004 10:21 PM
» Defender Registry
"London"
RHD90
Thebeast
marcd
Add your Defender
