Headlights? - Page 2 - Defender Source
Old December 12th, 2005, 10:21 AM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
Try Roundeyes.com, the Jeep 7" headlights worked GREAT for me...100$
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old December 12th, 2005, 11:06 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
As on "old schooler" - I run Cibie 7" lights - a little harder to find but a better light than Hellas in my opinion - I think I got my latest set from one of the Miata websites.
Old December 12th, 2005, 03:39 PM
Doug Aitken's Avatar
Doug Aitken
Doug Aitken
1995 D-90
Smile Duh: I just read page 2 of this thread....
Just decided to browse a bit and noticed this old thread on Headlamps.
A great alternative to all those "bling" headlamps is available from Alan Dobbs at GCR:
http://www.gulfcoastrovers.com/all/trucklite/index.htm
I've had mine for quite a few years and they flat WORK!
Doug
PS: OOPS: just went to page 2 of this thread and see some people mentioned these! Sorry. But my recommendation stands!!
Doug Aitken
1995 D-90
2001 Discovery II
Old December 12th, 2005, 04:15 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
LOL 'Gulf Coast Rover' and 'See installation on a Red Hummer'.......
However, it IS a photo of an H1, which is acceptable.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 12th, 2005, 05:49 PM
scoloco's Avatar
scoloco
'94 D90 ST
Originally Posted by Hans
Just remember that you may need to upgrade the wiring if you go with higher wattage bulbs than they come with.
-Hans
Upgrade the wiring? Or just use the relay deal so the switch doesnt get fried?
[the light ciruit goes through the hi/lo beam switch - so if you up the bulb wattage, you up the current through the switch and likely will burn it sooner rather than later].
Old December 12th, 2005, 06:17 PM
Hans's Avatar
Hans
Hans Haase
That's basically what I mean, though I like to run larger gauge wiring in the portion that runs to the bulbs. The factory stuff is really thin, but yes relay too.
-Hans
My oil line fix
Old December 12th, 2005, 06:42 PM
Is anybody running Sylvania Silverstar bulbs with factory wiring?
Old December 12th, 2005, 07:44 PM
I am running the silver star... I have not noticed any issues, except having to replace the light switch, which is a normal Defender problem.
Not to hi-jack this post, but has anyone done a Xenon/HID conversion? My buddy did his BMW, and it seemed pretty easy.
Old December 12th, 2005, 10:16 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
I am, and now that I say it something tells me I'll have to replace the switch...
"It's not a Jeep"
Old December 13th, 2005, 09:09 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Don't replace the switch, insert a harness that takes the load off the switch....
Then your switch will never fail.
Old December 13th, 2005, 03:27 PM
roverboy's Avatar
roverboy
Thomas
Booger
I'm curious about a xenon/HID conversion as well. Anyone done it?
"There is absolutely no excuse for the way I'm about to act."
Old December 13th, 2005, 04:10 PM
I know Martin Podgorski not sure on the spelling (myb) had some HID's I am sure he would be glad to tell you what he did to his truck
http://www.defendersource.com/forum/...ead.php?t=2645 that dude
ht, lights
Low Beam Headlights Quit JimC Defender Technical Discussions 7 January 29th, 2006 07:54 PM
installing Hella headlights oldscratchggf Defender Technical Discussions 5 December 25th, 2005 10:16 PM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
2 Defender headlights Disco_Stu For Sale - Parts 5 September 28th, 2005 11:59 AM
Yaaaaaaaaaaaarg! Frigging headlights solihul Defender Technical Discussions 2 June 23rd, 2005 10:29 PM
