Headlight Upgrade - Defender Source
Old July 27th, 2009, 01:21 PM
merlin8ty's Avatar
merlin8ty
Cliff Weinstein
1997 D-90 AA Yellow
Headlight Upgrade
My headlights are stock on my 97 D90. They are pretty awful when driving at night. Suggestions for the best headlight upgrade???? thanks
Old July 27th, 2009, 01:36 PM
I went with the IPF's from Expedition Exchange with the IPF bulbs
Old July 27th, 2009, 01:40 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Hella H4's myself, with the E-code lens. Also look into upgrading the wiring harness if you put any higher wattage bulbs in there, or you could end up melting the light switch.
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 27th, 2009, 02:26 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Some people feel the Hella E-Codes have a thinner Glass Lenses, and crack more easily from temperature changes like submerging them when hot. The IPF's are suppose to have a thicker, more resilient lenses. I've run the e-code Hella's for years without issue, but that is just my experience.
Either way do yourself a favor and put a headlamp harness in, even if you only intend to run stock wattage bulbs.
~Scott T.
'95 D-90 ST - AA Yellow
Old July 27th, 2009, 02:31 PM
merlin8ty's Avatar
merlin8ty
Cliff Weinstein
1997 D-90 AA Yellow
thanks, thoughts on these.
http://www.rallylights.com/detail.aspx?ID=136
Old July 27th, 2009, 02:47 PM
The first step is to upgrade the wiring. Expedition Exchange has a kit. There is also a DIY way to do it in the small projects section of this website. I have been meaning to do this but I have not had the chance.
Old July 27th, 2009, 03:21 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
The above is true, I have two broken hella e-codes on my truck. One by rocks one by cracks.
Old July 27th, 2009, 03:52 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I replaced my Headlights with H4's with the E-code lens and then bought a Bi-Xenon kit off ebay and installed that into the new headlights. They are extremely bright now, draw less power, should last a whole lot longer than conventional Halogen bulbs and with the Bi-Xenon kit they are true Xenon lights with the low or high beams on. I think the whole deal cost about $150!
Old July 27th, 2009, 03:59 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Originally Posted by merlin8ty
Go with the E-Codes. They are not technically DOT approved, but they provide much better lighting, and do not offend oncoming drivers the least bit more than a DOT headlamp. ARB makes a ready made harness (Per Ron's Suggestion) and Expedition Exchange sells both the HElla E-Codes, and the IPF Ecode replacement lamps as well as the harness. Its one of the best bang for the buck upgrades you can make..
~Scott T.
Old July 27th, 2009, 04:13 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
I replaced my headlights with crystal headlights that have a plain plastic lens with the reflector moulded to provide beam correction, with a pair of good quality H4's.
that made a hell of a difference.
Gren
Old July 29th, 2009, 09:18 AM
artpeck
Art Peck
1995 NAS D-90
For what it is worth, I replaced mine with the Hella H4 and put 80 watt low and 100 watt high bulbs into the lamps. The light (while not DOT approved for on road use) is bright and white and properly adjusted they have never been an issue for on coming drivers. Honestly they are far less annoying than many of the HID lights out there today. This does require a relay (worth doing anyway as the headlight switch is designed such that any significant wattage will eventually burn the contact out) and a wiring harness. It was an easy swap out and made a profound difference to night time driving all while retaining a very stock look and feel. These are available many places including EE and RN etc. My two cents.
Old July 29th, 2009, 12:11 PM
specops1526's Avatar
specops1526
Beluga '97 90
Sounds cool. Write up?
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old July 29th, 2009, 02:01 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
How's that working out? I would think that it would create an awful amount of glare for oncoming drivers, and pretty underwhelming overall results from the standpoints of the actual lighting pattern and cutoffs. I've always heard and
read that this is just a bad idea with headlamp housings designed for halogen bulbs, from a number of aspects (legal issues aside).
As a side note, Sylvania actually had 7" round replacement headlamps years ago that used an HID low beam and Halogen high beam. A 7" round headlamp truly designed for an HID bulb capsule. Unfortunately they stopped making them a long time ago.
You may want to try a simple E-Code Headlamp, quality bulb and wiring harness first, I suspect you will ultimately have better usable light output, and less trouble with oncoming drivers. I run the 80/100 watt bulbs with a wiring harness in E-Code Hellas and everyone who's been in the truck at night comments on how great the lightning is, and despite the height of the truck, I rarely ever have anyone flash me...
~Scott T.
Old July 29th, 2009, 02:24 PM
What/where did you get all this stuff?
Old July 29th, 2009, 02:40 PM
merlin8ty's Avatar
merlin8ty
Cliff Weinstein
1997 D-90 AA Yellow
The Hellas with the bi-xenon kit sounds great. Can someone elaborate on some specifics. Which kit works, there are dozens of choices.
http://shop.ebay.com/?_from=R40&_trk...w=bi-xenon+kit
Old July 29th, 2009, 09:44 PM
merlin8ty's Avatar
merlin8ty
Cliff Weinstein
1997 D-90 AA Yellow
Okay, going to tackle my first small mod on the truck. Basically Im looking for someones blessing on this. For the headlights im going to attempt the bi-xenon hid conversion. So....If i buy these
http://www.carparts.com/Headlight-Co...6_N__10618.car round
and the kit:
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_5425wt_1125
is that all i should need? Also what temperature would you guys recommend 4300 or 6000? Thanks in advance.
Old July 30th, 2009, 12:40 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Sorry, I owe some pictures too, but I haven't had a chance to take them or get back to people. They are working great although I haven't been driving the truck, they haven't given me any problems at all when I have used it and they are considerably brighter than the stock ones.
The E-code lights are really nice because you don't really need light shining up in the trees anyway, and they cut up on the right side to illuminate street signs, which is very useful.
Ron, I bought them on ebay.
Cliff, I have installed different kits in a number of cars and two motorcycles, and I think I have only bought two sets from the same seller. I believe I have installed a set from the seller you linked to even. I would recommend the 4300k (OEM for most manufacturers) as they give the most visible light, but it is up to you if you prefer the color of the 6000k. Any higher temps start to get really purple and emit considerably less visible light.
Those are NOT the Hellas that you want though! Those are sealed beams, which means, like the stock ones, you can not remove the bulb from the housing. You want the 7" round H4 Hellas. You need to specify that you want the H4 bulb base when you order the BiXenon's as well.
Old July 30th, 2009, 08:54 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
and the kit:
6000 is pretty close to daylight (5500k). It might appear more on the "bluish" side to you compared to halogen's. I think most factory HID's are around 5-6k)
4300k tend to be brighter, but don't have that "blue tinge" look the ricers are so fond of.
Old July 30th, 2009, 10:50 AM
merlin8ty's Avatar
merlin8ty
Cliff Weinstein
1997 D-90 AA Yellow
Made the decision. Although the xenons would be cool, I spoke with a guy from Susquehanna and he said in new york i would have problems getting pulled over for them. 6k fine, take the truck, basically a big pain in the ass. He recommened this set up.
H6024
H6024 7" Round E-code Hi-Lo Conversion Headlamp Kit.
Choose H4 Bulbs : H6024H 70/65W Osram Hyper
He said you will see a drastic improvement and still get the look of xenon. It seems they really know their stuff.
Old July 30th, 2009, 11:01 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
From what I recall of the wiring diagram & relays in the console, the 1997's already comes with headlight relays. I don't think this is the case for the '94's and 95's. With all the wiring bug-a-boo's, I feel this is one reason why BMW (then owner of LR) did not ship any D90's to NA in 1996.
Dennis
ht
OME upgrade advice kolvedic Defender Technical Discussions 11 August 16th, 2005 11:08 PM
97 defender st - headlight retaining screw Rob Defender Technical Discussions 1 April 25th, 2005 06:22 PM
Mesh Headlight Guard NashvilleRedD90 Defender Technical Discussions 5 April 18th, 2005 03:20 PM
Upgrade pushed back chrisvonc Misc. Chit-Chat 0 May 15th, 2004 11:23 AM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
» Defender Registry
BUD
BUD86
1st Defender
tom65
Add your Defender
